[petsc-users] Linear solver diverging
Wed Apr 1 10:58:21 CDT 2015
On Wed, Apr 1, 2015 at 10:51 AM, bichinhoverde <
bichinhoverde at spwinternet.com.br> wrote:
> I have a linear system which I can easily solve using the Pardiso library,
> which is a direct solver. But when I try Petsc, the solver does not
> converge. It reduces the norm a little but then gets stuck.
> I tried several combinations of pc_type and ksp_type. It seems that
> pc=jacobi is better, since my linear system does not have the diagonal
> element in some rows.
> Is there some advice you can give me? Some way to analyse the matrix and
> find out why it does not work?
Without knowing anything about the system, there is nothing you can say.
Why do you want to change from using a direct solver?
Have you looked in the literature for iterative solvers that work on this
problem?
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150401/20e2b6e0/attachment-0001.html>
