[petsc-users] Scaling/Preconditioners for Poisson equation
Mon Sep 29 08:58:35 CDT 2014
On Mon, Sep 29, 2014 at 8:42 AM, Filippo Leonardi <
filippo.leonardi at sam.math.ethz.ch> wrote:
> Hi,
> I am trying to solve a standard second order central differenced Poisson
> equation in parallel, in 3D, using a 3D structured DMDAs (extremely
> standard
> Laplacian matrix).
> I want to get some nice scaling (especially weak), but my results show that
> the Krylow method is not performing as expected. The problem (at leas for
> CG +
> Bjacobi)  seems to lie on the number of iterations.
> In particular the number of iterations grows with CG  (the matrix is SPD) +
> BJacobi as mesh is refined (probably due to condition number increasing)
> and
> number of processors is increased (probably due to the Bjacobi
> preconditioner). For instance I tried the following setup:
> 1 procs to solve 32^3 domain => 20 iterations
> 8 procs to solve 64^3 domain => 60 iterations
> 64  procs to solve 128^3 domain => 101 iterations
> Is there something pathological with my runs (maybe I am missing
> something)?
> Is there somebody who can provide me weak scaling benchmarks for equivalent
> problems? (Maybe there is some better preconditioner for this problem).
Bjacobi is not a scalable preconditioner. As you note, the number of
iterates grows
with the system size. You should always use MG here.
> I am also aware that Multigrid is even better for this problems but the
> **scalability** of my runs seems to be as bad as with CG.
MG will weak scale almost perfectly. Send -log_summary for each run if this
does not happen.
     Matt
> -pc_mg_galerkin
> -pc_type mg
> (both directly with richardson or as preconditioner to cg)
> The following is the "-log_summary" of a 128^3 run, notice that I solve the
> system multiple times (hence KSPSolve is multiplied by 128). Using CG +
> BJacobi.
> Tell me if I missed some detail and sorry for the length of the post.
> Thanks,
> Filippo
> Using Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
>                          Max       Max/Min        Avg      Total
> Time (sec):           9.095e+01      1.00001   9.095e+01
> Objects:              1.875e+03      1.00000   1.875e+03
> Flops:                1.733e+10      1.00000   1.733e+10  1.109e+12
> Flops/sec:            1.905e+08      1.00001   1.905e+08  1.219e+10
> MPI Messages:         1.050e+05      1.00594   1.044e+05  6.679e+06
> MPI Message Lengths:  1.184e+09      1.37826   8.283e+03  5.532e+10
> MPI Reductions:       4.136e+04      1.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N
> 2N flops
>                             and VecAXPY() for complex vectors of length N
> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
> -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts   %Total
>  0:      Main Stage: 1.1468e-01   0.1%  0.0000e+00   0.0%  0.000e+00   0.0%
> 0.000e+00        0.0%  0.000e+00   0.0%
>  1:       StepStage: 4.4170e-01   0.5%  7.2478e+09   0.7%  0.000e+00   0.0%
>  2:       ConvStage: 8.8333e+00   9.7%  3.7044e+10   3.3%  1.475e+06  22.1%
> 1.809e+03       21.8%  0.000e+00   0.0%
>  3:       ProjStage: 7.7169e+01  84.8%  1.0556e+12  95.2%  5.151e+06  77.1%
> 6.317e+03       76.3%  4.024e+04  97.3%
>  4:         IoStage: 2.4789e+00   2.7%  0.0000e+00   0.0%  3.564e+03   0.1%
> 1.017e+02        1.2%  5.000e+01   0.1%
>  5:       SolvAlloc: 7.0947e-01   0.8%  0.0000e+00   0.0%  5.632e+03   0.1%
> 9.587e-01        0.0%  3.330e+02   0.8%
>  6:       SolvSolve: 1.2044e+00   1.3%  9.1679e+09   0.8%  4.454e+04   0.7%
> 5.464e+01        0.7%  7.320e+02   1.8%
>  7:       SolvDeall: 7.5711e-04   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting
> output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    Avg. len: average message length
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
>       %T - percent time in this phase         %f - percent flops in this
> phase
>       %M - percent messages in this phase     %L - percent message lengths
> in
> this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> over all
> processors)
> Event                Count      Time (sec)     Flops
> --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> --- Event Stage 1: StepStage
> VecAXPY             1536 1.0 4.6436e-01 1.1 1.13e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0  99100  0  0  0 15608
> --- Event Stage 2: ConvStage
> VecCopy             2304 1.0 8.1658e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   9  0  0  0  0     0
> VecAXPY             2304 1.0 6.1324e-01 1.2 1.51e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   6 26  0  0  0 15758
> VecAXPBYCZ          2688 1.0 1.3029e+00 1.1 3.52e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  2  0  0  0  14 61  0  0  0 17306
> VecPointwiseMult    2304 1.0 7.2368e-01 1.0 7.55e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   8 13  0  0  0  6677
> VecScatterBegin     3840 1.0 1.8182e+00 1.3 0.00e+00 0.0 1.5e+06 8.2e+03
> 0.0e+00  2  0 22 22  0  18  0100100  0     0
> VecScatterEnd       3840 1.0 1.1972e+00 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0  10  0  0  0  0     0
> --- Event Stage 3: ProjStage
> VecTDot            25802 1.0 4.2552e+00 1.3 1.69e+09 1.0 0.0e+00 0.0e+00
> 2.6e+04  4 10  0  0 62   5 10  0  0 64 25433
> VecNorm            13029 1.0 3.0772e+00 3.3 8.54e+08 1.0 0.0e+00 0.0e+00
> 1.3e+04  2  5  0  0 32   2  5  0  0 32 17759
> VecCopy              640 1.0 2.4339e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecSet             13157 1.0 7.0903e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> VecAXPY            26186 1.0 4.1462e+00 1.1 1.72e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  4 10  0  0  0   5 10  0  0  0 26490
> VecAYPX            12773 1.0 1.9135e+00 1.1 8.37e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  5  0  0  0   2  5  0  0  0 27997
> VecScatterBegin    13413 1.0 1.0689e+00 1.1 0.00e+00 0.0 5.2e+06 8.2e+03
> 0.0e+00  1  0 77 76  0   1  0100100  0     0
> VecScatterEnd      13413 1.0 2.7944e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   3  0  0  0  0     0
> MatMult            12901 1.0 3.2072e+01 1.0 5.92e+09 1.0 5.0e+06 8.2e+03
> 0.0e+00 35 34 74 73  0  41 36 96 96  0 11810
> MatSolve           13029 1.0 3.0851e+01 1.1 5.39e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00 33 31  0  0  0  39 33  0  0  0 11182
> MatLUFactorNum       128 1.0 1.2922e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   2  1  0  0  0  4358
> MatILUFactorSym      128 1.0 7.5075e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.3e+02  1  0  0  0  0   1  0  0  0  0     0
> MatGetRowIJ          128 1.0 1.4782e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering       128 1.0 5.7567e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.6e+02  0  0  0  0  1   0  0  0  0  1     0
> KSPSetUp             256 1.0 1.9913e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 7.7e+02  0  0  0  0  2   0  0  0  0  2     0
> KSPSolve             128 1.0 7.6381e+01 1.0 1.65e+10 1.0 5.0e+06 8.2e+03
> 4.0e+04 84 95 74 73 97  99100 96 96100 13800
> PCSetUp              256 1.0 2.1503e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
> 6.4e+02  2  1  0  0  2   3  1  0  0  2  2619
> PCSetUpOnBlocks      128 1.0 2.1232e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
> 3.8e+02  2  1  0  0  1   3  1  0  0  1  2652
> PCApply            13029 1.0 3.1812e+01 1.1 5.39e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00 34 31  0  0  0  40 33  0  0  0 10844
> --- Event Stage 4: IoStage
> VecView               10 1.0 1.7523e+00282.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+01  1  0  0  0  0  36  0  0  0 40     0
> VecCopy               10 1.0 2.2449e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin        6 1.0 2.3620e-03 2.4 0.00e+00 0.0 2.3e+03 8.2e+03
> 0.0e+00  0  0  0  0  0   0  0 65  3  0     0
> VecScatterEnd          6 1.0 4.4194e-01663.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   9  0  0  0  0     0
> --- Event Stage 5: SolvAlloc
> VecSet                50 1.0 1.3170e-01 5.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  13  0  0  0  0     0
> MatAssemblyBegin       4 1.0 3.9801e-0230.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 8.0e+00  0  0  0  0  0   3  0  0  0  2     0
> MatAssemblyEnd         4 1.0 2.2752e-02 1.0 0.00e+00 0.0 1.5e+03 2.0e+03
> 1.6e+01  0  0  0  0  0   3  0 27 49  5     0
> --- Event Stage 6: SolvSolve
> VecTDot              224 1.0 3.5454e-02 1.3 1.47e+07 1.0 0.0e+00 0.0e+00
> 2.2e+02  0  0  0  0  1   3 10  0  0 31 26499
> VecNorm              497 1.0 1.5268e-01 1.4 7.41e+06 1.0 0.0e+00 0.0e+00
> 5.0e+02  0  0  0  0  1  11  5  0  0 68  3104
> VecCopy                8 1.0 2.7523e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet               114 1.0 5.9965e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY              230 1.0 3.7198e-02 1.1 1.51e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   3 11  0  0  0 25934
> VecAYPX              111 1.0 1.7153e-02 1.1 7.27e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   1  5  0  0  0 27142
> VecScatterBegin      116 1.0 1.1888e-02 1.2 0.00e+00 0.0 4.5e+04 8.2e+03
> 0.0e+00  0  0  1  1  0   1  0100100  0     0
> VecScatterEnd        116 1.0 2.8105e-02 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
> MatMult              112 1.0 2.8080e-01 1.0 5.14e+07 1.0 4.3e+04 8.2e+03
> 0.0e+00  0  0  1  1  0  23 36 97 97  0 11711
> MatSolve             113 1.0 2.6673e-01 1.1 4.67e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  22 33  0  0  0 11217
> MatLUFactorNum         1 1.0 1.0332e-02 1.0 6.87e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   1  0  0  0  0  4259
> MatILUFactorSym        1 1.0 3.1291e-02 4.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00  0  0  0  0  0   2  0  0  0  0     0
> MatGetRowIJ            1 1.0 4.0531e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering         1 1.0 3.4251e-03 5.4 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> KSPSetUp               2 1.0 3.6959e-0210.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.0e+00  0  0  0  0  0   1  0  0  0  1     0
> KSPSolve               1 1.0 6.9956e-01 1.0 1.43e+08 1.0 4.3e+04 8.2e+03
> 3.5e+02  1  1  1  1  1  58100 97 97 48 13069
> PCSetUp                2 1.0 4.4161e-02 2.3 6.87e+05 1.0 0.0e+00 0.0e+00
> 5.0e+00  0  0  0  0  0   3  0  0  0  1   996
> PCSetUpOnBlocks        1 1.0 4.3894e-02 2.4 6.87e+05 1.0 0.0e+00 0.0e+00
> 3.0e+00  0  0  0  0  0   3  0  0  0  0  1002
> PCApply              113 1.0 2.7507e-01 1.1 4.67e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  22 33  0  0  0 10877
> --- Event Stage 7: SolvDeall
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Viewer     1              0            0     0
>               Vector   640            640    101604352     0
>               Matrix   128            128    410327040     0
>            Index Set   384            384     17062912     0
>        Krylov Solver   256            256       282624     0
>       Preconditioner   256            256       228352     0
>               Vector    10             10      2636400     0
>               Viewer    10             10         6880     0
>               Vector   140              6         8848     0
>       Vector Scatter     6              0            0     0
>               Matrix     6              0            0     0
>     Distributed Mesh     2              0            0     0
>      Bipartite Graph     4              0            0     0
>            Index Set    14             14       372400     0
>    IS L to G Mapping     3              0            0     0
>        Krylov Solver     1              0            0     0
>       Preconditioner     1              0            0     0
>               Vector     5              0            0     0
>               Matrix     1              0            0     0
>            Index Set     3              0            0     0
>        Krylov Solver     2              1         1136     0
>       Preconditioner     2              1          824     0
>               Vector     0            133     36676728     0
>       Vector Scatter     0              1         1036     0
>               Matrix     0              4      7038924     0
>            Index Set     0              3       133304     0
>        Krylov Solver     0              2         2208     0
>       Preconditioner     0              2         1784     0
> Average time to get PetscTime(): 9.53674e-08
> Average time for MPI_Barrier(): 1.12057e-05
> Average time for zero size MPI_Send(): 1.3113e-06
> #PETSc Option Table entries:
> -ksp_type cg
> -log_summary
> -pc_type bjacobi
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure run at:
> Configure options:
> Application 9457215 resources: utime ~5920s, stime ~58s
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140929/d8166c56/attachment-0001.html>
