[petsc-users] Scaling/Preconditioners for Poisson equation
Filippo Leonardi filippo.leonardi at sam.math.ethz.ch
Mon Sep 29 08:42:19 CDT 2014
I am trying to solve a standard second order central differenced Poisson
equation in parallel, in 3D, using a 3D structured DMDAs (extremely standard
Laplacian matrix).
I want to get some nice scaling (especially weak), but my results show that
the Krylow method is not performing as expected. The problem (at leas for CG +
Bjacobi)  seems to lie on the number of iterations.
In particular the number of iterations grows with CG  (the matrix is SPD) +
BJacobi as mesh is refined (probably due to condition number increasing) and
number of processors is increased (probably due to the Bjacobi
preconditioner). For instance I tried the following setup:
1 procs to solve 32^3 domain => 20 iterations
8 procs to solve 64^3 domain => 60 iterations
64  procs to solve 128^3 domain => 101 iterations
Is there something pathological with my runs (maybe I am missing something)?
Is there somebody who can provide me weak scaling benchmarks for equivalent
problems? (Maybe there is some better preconditioner for this problem).
I am also aware that Multigrid is even better for this problems but the
**scalability** of my runs seems to be as bad as with CG.
-pc_mg_galerkin
-pc_type mg
(both directly with richardson or as preconditioner to cg)
The following is the "-log_summary" of a 128^3 run, notice that I solve the
system multiple times (hence KSPSolve is multiplied by 128). Using CG +
BJacobi.
Tell me if I missed some detail and sorry for the length of the post.
Filippo
Using Petsc Release Version 3.3.0, Patch 3, Wed Aug 29 11:26:24 CDT 2012
                         Max       Max/Min        Avg      Total
Time (sec):           9.095e+01      1.00001   9.095e+01
Objects:              1.875e+03      1.00000   1.875e+03
Flops:                1.733e+10      1.00000   1.733e+10  1.109e+12
Flops/sec:            1.905e+08      1.00001   1.905e+08  1.219e+10
MPI Messages:         1.050e+05      1.00594   1.044e+05  6.679e+06
MPI Message Lengths:  1.184e+09      1.37826   8.283e+03  5.532e+10
MPI Reductions:       4.136e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N -->
2N flops
                            and VecAXPY() for complex vectors of length N -->
8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---
-- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total
 0:      Main Stage: 1.1468e-01   0.1%  0.0000e+00   0.0%  0.000e+00   0.0%
0.000e+00        0.0%  0.000e+00   0.0%
 1:       StepStage: 4.4170e-01   0.5%  7.2478e+09   0.7%  0.000e+00   0.0%
 2:       ConvStage: 8.8333e+00   9.7%  3.7044e+10   3.3%  1.475e+06  22.1%
1.809e+03       21.8%  0.000e+00   0.0%
 3:       ProjStage: 7.7169e+01  84.8%  1.0556e+12  95.2%  5.151e+06  77.1%
6.317e+03       76.3%  4.024e+04  97.3%
 4:         IoStage: 2.4789e+00   2.7%  0.0000e+00   0.0%  3.564e+03   0.1%
1.017e+02        1.2%  5.000e+01   0.1%
 5:       SolvAlloc: 7.0947e-01   0.8%  0.0000e+00   0.0%  5.632e+03   0.1%
9.587e-01        0.0%  3.330e+02   0.8%
 6:       SolvSolve: 1.2044e+00   1.3%  9.1679e+09   0.8%  4.454e+04   0.7%
5.464e+01        0.7%  7.320e+02   1.8%
 7:       SolvDeall: 7.5711e-04   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting
output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in
this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all
processors)
Event                Count      Time (sec)     Flops
--- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
--- Event Stage 1: StepStage
VecAXPY             1536 1.0 4.6436e-01 1.1 1.13e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0  99100  0  0  0 15608
--- Event Stage 2: ConvStage
VecCopy             2304 1.0 8.1658e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   9  0  0  0  0     0
VecAXPY             2304 1.0 6.1324e-01 1.2 1.51e+08 1.0 0.0e+00 0.0e+00
0.0e+00  1  1  0  0  0   6 26  0  0  0 15758
VecAXPBYCZ          2688 1.0 1.3029e+00 1.1 3.52e+08 1.0 0.0e+00 0.0e+00
0.0e+00  1  2  0  0  0  14 61  0  0  0 17306
VecPointwiseMult    2304 1.0 7.2368e-01 1.0 7.55e+07 1.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   8 13  0  0  0  6677
VecScatterBegin     3840 1.0 1.8182e+00 1.3 0.00e+00 0.0 1.5e+06 8.2e+03
0.0e+00  2  0 22 22  0  18  0100100  0     0
VecScatterEnd       3840 1.0 1.1972e+00 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0  10  0  0  0  0     0
--- Event Stage 3: ProjStage
VecTDot            25802 1.0 4.2552e+00 1.3 1.69e+09 1.0 0.0e+00 0.0e+00
2.6e+04  4 10  0  0 62   5 10  0  0 64 25433
VecNorm            13029 1.0 3.0772e+00 3.3 8.54e+08 1.0 0.0e+00 0.0e+00
1.3e+04  2  5  0  0 32   2  5  0  0 32 17759
VecCopy              640 1.0 2.4339e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             13157 1.0 7.0903e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            26186 1.0 4.1462e+00 1.1 1.72e+09 1.0 0.0e+00 0.0e+00
0.0e+00  4 10  0  0  0   5 10  0  0  0 26490
VecAYPX            12773 1.0 1.9135e+00 1.1 8.37e+08 1.0 0.0e+00 0.0e+00
0.0e+00  2  5  0  0  0   2  5  0  0  0 27997
VecScatterBegin    13413 1.0 1.0689e+00 1.1 0.00e+00 0.0 5.2e+06 8.2e+03
0.0e+00  1  0 77 76  0   1  0100100  0     0
VecScatterEnd      13413 1.0 2.7944e+00 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  2  0  0  0  0   3  0  0  0  0     0
MatMult            12901 1.0 3.2072e+01 1.0 5.92e+09 1.0 5.0e+06 8.2e+03
0.0e+00 35 34 74 73  0  41 36 96 96  0 11810
MatSolve           13029 1.0 3.0851e+01 1.1 5.39e+09 1.0 0.0e+00 0.0e+00
0.0e+00 33 31  0  0  0  39 33  0  0  0 11182
MatLUFactorNum       128 1.0 1.2922e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
0.0e+00  1  1  0  0  0   2  1  0  0  0  4358
MatILUFactorSym      128 1.0 7.5075e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
1.3e+02  1  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ          128 1.0 1.4782e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering       128 1.0 5.7567e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
2.6e+02  0  0  0  0  1   0  0  0  0  1     0
KSPSetUp             256 1.0 1.9913e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
7.7e+02  0  0  0  0  2   0  0  0  0  2     0
KSPSolve             128 1.0 7.6381e+01 1.0 1.65e+10 1.0 5.0e+06 8.2e+03
4.0e+04 84 95 74 73 97  99100 96 96100 13800
PCSetUp              256 1.0 2.1503e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
6.4e+02  2  1  0  0  2   3  1  0  0  2  2619
PCSetUpOnBlocks      128 1.0 2.1232e+00 1.0 8.80e+07 1.0 0.0e+00 0.0e+00
3.8e+02  2  1  0  0  1   3  1  0  0  1  2652
PCApply            13029 1.0 3.1812e+01 1.1 5.39e+09 1.0 0.0e+00 0.0e+00
0.0e+00 34 31  0  0  0  40 33  0  0  0 10844
--- Event Stage 4: IoStage
VecView               10 1.0 1.7523e+00282.9 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+01  1  0  0  0  0  36  0  0  0 40     0
VecCopy               10 1.0 2.2449e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin        6 1.0 2.3620e-03 2.4 0.00e+00 0.0 2.3e+03 8.2e+03
0.0e+00  0  0  0  0  0   0  0 65  3  0     0
VecScatterEnd          6 1.0 4.4194e-01663.9 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   9  0  0  0  0     0
--- Event Stage 5: SolvAlloc
VecSet                50 1.0 1.3170e-01 5.6 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0  13  0  0  0  0     0
MatAssemblyBegin       4 1.0 3.9801e-0230.0 0.00e+00 0.0 0.0e+00 0.0e+00
8.0e+00  0  0  0  0  0   3  0  0  0  2     0
MatAssemblyEnd         4 1.0 2.2752e-02 1.0 0.00e+00 0.0 1.5e+03 2.0e+03
1.6e+01  0  0  0  0  0   3  0 27 49  5     0
--- Event Stage 6: SolvSolve
VecTDot              224 1.0 3.5454e-02 1.3 1.47e+07 1.0 0.0e+00 0.0e+00
2.2e+02  0  0  0  0  1   3 10  0  0 31 26499
VecNorm              497 1.0 1.5268e-01 1.4 7.41e+06 1.0 0.0e+00 0.0e+00
5.0e+02  0  0  0  0  1  11  5  0  0 68  3104
VecCopy                8 1.0 2.7523e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet               114 1.0 5.9965e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY              230 1.0 3.7198e-02 1.1 1.51e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   3 11  0  0  0 25934
VecAYPX              111 1.0 1.7153e-02 1.1 7.27e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   1  5  0  0  0 27142
VecScatterBegin      116 1.0 1.1888e-02 1.2 0.00e+00 0.0 4.5e+04 8.2e+03
0.0e+00  0  0  1  1  0   1  0100100  0     0
VecScatterEnd        116 1.0 2.8105e-02 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatMult              112 1.0 2.8080e-01 1.0 5.14e+07 1.0 4.3e+04 8.2e+03
0.0e+00  0  0  1  1  0  23 36 97 97  0 11711
MatSolve             113 1.0 2.6673e-01 1.1 4.67e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0  22 33  0  0  0 11217
MatLUFactorNum         1 1.0 1.0332e-02 1.0 6.87e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   1  0  0  0  0  4259
MatILUFactorSym        1 1.0 3.1291e-02 4.2 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatGetRowIJ            1 1.0 4.0531e-06 4.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 1.0 3.4251e-03 5.4 0.00e+00 0.0 0.0e+00 0.0e+00
2.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp               2 1.0 3.6959e-0210.1 0.00e+00 0.0 0.0e+00 0.0e+00
6.0e+00  0  0  0  0  0   1  0  0  0  1     0
KSPSolve               1 1.0 6.9956e-01 1.0 1.43e+08 1.0 4.3e+04 8.2e+03
3.5e+02  1  1  1  1  1  58100 97 97 48 13069
PCSetUp                2 1.0 4.4161e-02 2.3 6.87e+05 1.0 0.0e+00 0.0e+00
5.0e+00  0  0  0  0  0   3  0  0  0  1   996
PCSetUpOnBlocks        1 1.0 4.3894e-02 2.4 6.87e+05 1.0 0.0e+00 0.0e+00
3.0e+00  0  0  0  0  0   3  0  0  0  0  1002
PCApply              113 1.0 2.7507e-01 1.1 4.67e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0  22 33  0  0  0 10877
--- Event Stage 7: SolvDeall
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     1              0            0     0
              Vector   640            640    101604352     0
              Matrix   128            128    410327040     0
           Index Set   384            384     17062912     0
       Krylov Solver   256            256       282624     0
      Preconditioner   256            256       228352     0
              Vector    10             10      2636400     0
              Viewer    10             10         6880     0
              Vector   140              6         8848     0
      Vector Scatter     6              0            0     0
              Matrix     6              0            0     0
    Distributed Mesh     2              0            0     0
     Bipartite Graph     4              0            0     0
           Index Set    14             14       372400     0
   IS L to G Mapping     3              0            0     0
       Krylov Solver     1              0            0     0
      Preconditioner     1              0            0     0
              Vector     5              0            0     0
              Matrix     1              0            0     0
           Index Set     3              0            0     0
       Krylov Solver     2              1         1136     0
      Preconditioner     2              1          824     0
              Vector     0            133     36676728     0
      Vector Scatter     0              1         1036     0
              Matrix     0              4      7038924     0
           Index Set     0              3       133304     0
       Krylov Solver     0              2         2208     0
      Preconditioner     0              2         1784     0
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 1.12057e-05
Average time for zero size MPI_Send(): 1.3113e-06
#PETSc Option Table entries:
-ksp_type cg
-log_summary
-pc_type bjacobi
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at:
Configure options:
Application 9457215 resources: utime ~5920s, stime ~58s
Type: text/vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140929/32bf1c7d/attachment-0001.bin>
