[petsc-users] GPU speedup in Poisson solvers
Ashwin Srinath ashwinsrnth at gmail.com
Fri Sep 26 10:14:17 CDT 2014
Thanks Dominic! I'll give you some feedback soon!
On Fri, Sep 26, 2014 at 11:16 AM, Dominic Meiser <dmeiser at txcorp.com> wrote:
> On 09/22/2014 01:47 PM, Ashwin Srinath wrote:
>> Dominic, I second a request for such a branch.
>> Thanks,
>> Ashwin
>>  Hi Ashwin,
> I put together a branch with our GPU bug fixes:
> https://github.com/Tech-XCorp/petsc/
> There is only one branch in this repo: gpu-master. Be aware that this
> branch is even more experimental than petsc/next. It contains experimental
> code that may be wrong or that will change before this can be merged into
> petsc/next or petsc/master. Let me know if you run into problems.
> Karl, this branch may also be helpful in reviewing PR #178.
> Cheers,
> Dominic
> Dominic Meiser
> Tech-X Corporation
> 5621 Arapahoe Avenue
> Boulder, CO 80303
> USA
> Telephone: 303-996-2036
> Fax: 303-448-7756
> www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140926/e72b8421/attachment.html>
