[petsc-users] GPU speedup in Poisson solvers
Dominic Meiser dmeiser at txcorp.com
Fri Sep 26 10:16:41 CDT 2014
On 09/22/2014 01:47 PM, Ashwin Srinath wrote:
> Dominic, I second a request for such a branch.
> Thanks,
> Ashwin
Hi Ashwin,
I put together a branch with our GPU bug fixes:
https://github.com/Tech-XCorp/petsc/
There is only one branch in this repo: gpu-master. Be aware that this
branch is even more experimental than petsc/next. It contains
experimental code that may be wrong or that will change before this can
be merged into petsc/next or petsc/master. Let me know if you run into
problems.
Karl, this branch may also be helpful in reviewing PR #178.
Cheers,
Dominic
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
