[petsc-users] Laplacian at infinity
Mon Sep 22 19:58:19 CDT 2014
On Mon, Sep 22, 2014 at 8:51 PM, John Alletto <4bikerboyjohn at gmail.com>
wrote:
> Are there any PML example problems using PETSc?
I do not believe we have any.
     Matt
> John
> On Sep 22, 2014, at 7:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 22, 2014 at 9:08 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > On Mon, Sep 22, 2014 at 7:36 AM, John Alletto <4bikerboyjohn at gmail.com>
>> > wrote:
>> >> All,
>> >> I am try to match some E&M problems with analytical solutions.
>> >> How do I deal with infinity when using a uniform grid ?
>> > It depends on your problem. Keep making it bigger and see if you get
>> > convergence.
>> This is a way to assess error caused by the finite grid, but you can
>> also use an analytic solution for that.  Using an asymptotic expansion
>> for the boundary condition can be useful (esp. when there is nonzero
>> charge in the domain, for example).  For wave propagation, look at
>> perfectly matched layers (PML).
> PML is the best option, although many codes simply use attenuation.
>    Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140922/c159dfac/attachment.html>
