[petsc-users] Laplacian at infinity
John Alletto 4bikerboyjohn at gmail.com
Mon Sep 22 19:51:14 CDT 2014
Are there any PML example problems using PETSc?
John
On Sep 22, 2014, at 7:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 22, 2014 at 9:08 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Mon, Sep 22, 2014 at 7:36 AM, John Alletto <4bikerboyjohn at gmail.com>
> > wrote:
> >> All,
> >> I am try to match some E&M problems with analytical solutions.
> >> How do I deal with infinity when using a uniform grid ?
> > It depends on your problem. Keep making it bigger and see if you get
> > convergence.
> This is a way to assess error caused by the finite grid, but you can
> also use an analytic solution for that.  Using an asymptotic expansion
> for the boundary condition can be useful (esp. when there is nonzero
> charge in the domain, for example).  For wave propagation, look at
> perfectly matched layers (PML).
> PML is the best option, although many codes simply use attenuation.
>    Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140922/5dd07a00/attachment.html>
