[petsc-users] PETSc/TAU configuration
Tue Sep 16 08:21:41 CDT 2014
I haven't tried using TAU in a while - but here are some obvious things to try.
1. --download-mpich [or openmpi] with TAU does not make sense.
You would have to build MPICH/OpenMPI first.
Then build TAU to use this MPI.
And then build PETSc to use this TAU_CC/MPI
2. I would use only tau_cc.sh - and not bother with c++/fortran
i.e [with TAU build with a given mpicc] - configure PETSc with:
./configure --with-cc=tau_cc.sh --with-cxx=mpicxx --with-fc=mpif90
3. Do not use any --download-package when using tau_cc.sh. First check
if you are able to use TAU with PETSc - without externalpackages [you
would need blas,mpi. Use system blas/lapack for blas/lapack - and
build MPI as mentioned above for use with TAU and later PETSc]
And if you really need these externalpackage [assuming the above basic
build with TAU works] - I would recommend the following 2 step build process:
<build packages without TAU>
4.1. ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-PACKAGE PETSC_ARCH=arch-packages
4.2. Now strip out the petsc relavent stuff from this location
rm -f arch-packages/include/petsc*.h
4.3. Now build PETSc with TAU - using these prebuilt-packages
./configure --with-cc=tau_cc.sh --with-cxx=mpicxx --with-fc=mpif90 PETSC_ARCH=arch-tau --with-PACKAGE-dir=`pwd`/arch-packages
BTW: the current release is petsc-3.5 - we recommend upgrading to
using it [as we usually support the latest release wrt debugging/bug
fixes]
Satish
1. dont use any download packages. If you need them - you have to
build them separately.
One way to do this - is to let petsc do the build like:
./configure --download-package PETSC_ARCH=arch-packages
[then remove
On Tue, 16 Sep 2014, Matthew Hills wrote:
> Hi PETSc Team,
> I am experiencing difficulties with configuring PETSc with TAU. I have replaced the standard compilers with the tau_cc.sh, tau_cxx.sh, and tau_f90.sh scripts but this produces multiple errors. I have also attempted to use OpenMPI and MPICH, but both produce their own unique errors.
> After successfully compiling PDT, TAU was compiled with:
> ./configure
> -prefix=`pwd`
> -cc=gcc
> -c++=g++ -fortran=gfortran
> -pdt=${SESKADIR}/packages/pdt
> -mpiinc=${PETSC_DIR}/${PETSC_ARCH}/include
> -mpilib=${PETSC_DIR}/${PETSC_ARCH}/lib -bfd=download
> Attached you'll find the PETSc configuration logs. If any more information is needed please let me know.
> Warm regards,
> Matthew HillsUniversity of Cape Town
