[petsc-users] Loosing a flux when using the asm preconditioned for >2 cores
Wed Sep 3 15:02:26 CDT 2014
  Force really tight convergence on the nonlinear solver -snes_rtol 1.e-12
  Note also that initial function norm
  0 SNES Function norm 2.418625311837e+01
  0 SNES Function norm 3.156023513435e+04
is very different in the two cases. This means either you are solving a different nonlinear problem on 2 and 3 processes or the initial conditions are very different (or both).
  Barry
On Sep 3, 2014, at 2:05 PM, Welland, Michael J. <mwelland at anl.gov> wrote:
> Thanks Barry, I attach the terminal outputs. From my reading, it seems like everything converged alright, no? Usually I get an error message when the linear or snes solver doesn't converge.
> By the way, I don't think it should matter but for your reference I am doing an operator split method in FEniCS where I am alternating between solving two system until their solution vectors stop changing between iterations.
> Thanks
> <correct_fluxes.txt><lost_fluxes.txt>
