[petsc-users] Loosing a flux when using the asm preconditioned for >2 cores
Wed Sep 3 13:36:07 CDT 2014
  Start by running with -snes_converged_reason -snes_monitor -ksp_converged_reason -ksp_monitor_true_residual -snes_linesearch_monitor
on two and then three cores.
  By default, “not converging” of an iterative solver does not generate an error so the most likely cause is that the iterative scheme is just not converging with more processors.
   Barry
On Sep 3, 2014, at 1:32 PM, Welland, Michael J. <mwelland at anl.gov> wrote:
> Hi all,
> I'm simulating a problem with small fluxes, using the asm preconditioner and lu as the sub preconditioner. The simulation runs fine using 2 cores, but when I use more the fluxes disappear and the desired effect goes with them.
> Does anyone have an idea of a suitable tolerance or parameter I should adjust? I am using the snes solver via the FEniCS package.
> Thanks,
> Mike
> I attach an snes terminal output for reference:
> SNES Object: 16 MPI processes
>   type: newtonls
>   maximum iterations=30, maximum function evaluations=2000
>   tolerances: relative=0.99, absolute=1e-05, solution=1e-10
>   total number of linear solver iterations=59
>   total number of function evaluations=2
>   SNESLineSearch Object:   16 MPI processes
>     type: basic
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
>     maximum iterations=1
>   KSP Object:   16 MPI processes
>     type: gmres
>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>     left preconditioning
>     using PRECONDITIONED norm type for convergence test
>   PC Object:   16 MPI processes
>     type: asm
>       Additive Schwarz: total subdomain blocks = 16, amount of overlap = 5
>       Additive Schwarz: restriction/interpolation type - NONE
>       Local solve is same for all blocks, in the following KSP and PC objects:
>     KSP Object:    (sub_)     1 MPI processes
>       type: preonly
>       using NONE norm type for convergence test
>     PC Object:    (sub_)     1 MPI processes
>       type: lu
>         LU: out-of-place factorization
>         tolerance for zero pivot 2.22045e-14
>         matrix ordering: nd
>         factor fill ratio given 5, needed 5.25151
>           Factored matrix follows:
>             Matrix Object:             1 MPI processes
>               type: seqaij
>               rows=4412, cols=4412
>               package used to perform factorization: petsc
>               total: nonzeros=626736, allocated nonzeros=626736
>               total number of mallocs used during MatSetValues calls =0
>                 using I-node routines: found 1103 nodes, limit used is 5
>       linear system matrix = precond matrix:
>         type: seqaij
>         total: nonzeros=119344, allocated nonzeros=119344
>     Matrix Object:     16 MPI processes
>       type: mpiaij
>       rows=41820, cols=41820, bs=4
>       total: nonzeros=1161136, allocated nonzeros=1161136
>         using I-node (on process 0) routines: found 638 nodes, limit used is 5
