[petsc-users] Loosing a flux when using the asm preconditioned for >2 cores
Welland, Michael J. mwelland at anl.gov
Wed Sep 3 13:32:44 CDT 2014
Hi all,
I'm simulating a problem with small fluxes, using the asm preconditioner and lu as the sub preconditioner. The simulation runs fine using 2 cores, but when I use more the fluxes disappear and the desired effect goes with them.
Does anyone have an idea of a suitable tolerance or parameter I should adjust? I am using the snes solver via the FEniCS package.
Mike
I attach an snes terminal output for reference:
SNES Object: 16 MPI processes
  type: newtonls
  maximum iterations=30, maximum function evaluations=2000
  tolerances: relative=0.99, absolute=1e-05, solution=1e-10
  total number of linear solver iterations=59
  total number of function evaluations=2
  SNESLineSearch Object:   16 MPI processes
    type: basic
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
    maximum iterations=1
  KSP Object:   16 MPI processes
    type: gmres
      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
      GMRES: happy breakdown tolerance 1e-30
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object:   16 MPI processes
    type: asm
      Additive Schwarz: total subdomain blocks = 16, amount of overlap = 5
      Additive Schwarz: restriction/interpolation type - NONE
      Local solve is same for all blocks, in the following KSP and PC objects:
    KSP Object:    (sub_)     1 MPI processes
      type: preonly
      using NONE norm type for convergence test
    PC Object:    (sub_)     1 MPI processes
      type: lu
        LU: out-of-place factorization
        tolerance for zero pivot 2.22045e-14
        matrix ordering: nd
        factor fill ratio given 5, needed 5.25151
          Factored matrix follows:
            Matrix Object:             1 MPI processes
              type: seqaij
              rows=4412, cols=4412
              package used to perform factorization: petsc
              total: nonzeros=626736, allocated nonzeros=626736
              total number of mallocs used during MatSetValues calls =0
                using I-node routines: found 1103 nodes, limit used is 5
      linear system matrix = precond matrix:
        type: seqaij
        total: nonzeros=119344, allocated nonzeros=119344
    Matrix Object:     16 MPI processes
      type: mpiaij
      rows=41820, cols=41820, bs=4
      total: nonzeros=1161136, allocated nonzeros=1161136
        using I-node (on process 0) routines: found 638 nodes, limit used is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/c9cb1b2f/attachment.html>
