[petsc-users] FETI-DP implementation and call sequence
Stefano Zampini stefano.zampini at gmail.com
Wed Sep 3 10:18:31 CDT 2014
FETIDP is in PETSc as a byproduct of the BDDC preconditioner (one is the dual of the other) and it does not have its own classes so far.
That said, you can experiment with FETI-DP only after having setup a BDDC preconditioner with the options and customization you prefer.
Use http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/KSP/index.html for manual pages.
For an 'how to' with FETIDP, please see src/ksp/ksp/examples/tutorials/ex.59.c as Jed told you, specifically look at ComputeKSPFETIDP for obtaining the FETIDP matrix F (implemented Matrix-free) and the optimal FETIDP dirichlet preconditioner. Once you have F, you can use PCBDDCMatFETIDPGetRHS and PCBDDCMatFetiDPGetSolution to obtain a right-hand side for the FETIDP system and a physical solution from the solution of the FETIDP system.
I would recommend you to use the development version of the library and either use the ‘next’ branch or the ‘master' branch after having merged in the branch stefano_zampini/pcbddc-primalfixes. Note that ‘next’ also contains the new deluxe scaling operator for BDDC which is not available to use with FETI-DP.
If you have any other questions which can be useful for other PETSc users, please use the mailing list; otherwise you can contact me personally.
Stefano
On Sep 3, 2014, at 5:19 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>>> 1- Is it possible to complete a FETI-DP solution with the provided
>>> functions in current PetSc release?
>> There is no FETI-DP in PETSc.
> Wrong.  There is PCBDDC, which has the same eigenvalues as FETI-DP.  You
> can enable it by configuring --with-pcbddc.  This will be turned on by
> default soon.  It is fairly new, so you should use the branch 'master'
> instead of the release.  It has an option to do FETI-DP instead of BDDC.
> See src/ksp/ksp/examples/tutorials/ex59.c.
> For either of these methods, you have to assemble a MATIS.  If you use
> MatSetValuesLocal, most of your assembly code can stay the same.
> Hopefully we can get better examples before the next release.  Stefano
> (the author of PCBDDC, Cc'd) tests mostly with external packages, but we
> really need more complete tests within PETSc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140903/4cd357ae/attachment.html>
