[petsc-users] Error while running src/snes/examples/tutorials/ex70.c
Gautam Bisht gbisht at lbl.gov
Fri Oct 31 21:47:25 CDT 2014
All,
I found an earlier email thread
<http://lists.mcs.anl.gov/pipermail/petsc-users/2014-July/022207.html> on
this topic. So, disregard this email.
-Gautam.
On Fri, Oct 31, 2014 at 9:35 AM, Gautam Bisht <gbisht at lbl.gov> wrote:
> Hi,
> I'm trying to learn how to use Schur complement as a preconditioner. I
> ran src/snes/examples/tutorials/ex70.c for the two cases:
> ./ex70 -user_pc -ksp_view
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: none
>   linear system matrix = precond matrix:
>   Mat Object:   1 MPI processes
>     type: nest
>     rows=72, cols=72
>       Matrix object:
>         type=nest, rows=2, cols=2
>         MatNest structure:
>         (0,0) : prefix="a00_", type=mpiaij, rows=48, cols=48
>         (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
>         (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
>         (1,1) : prefix="a11_", type=mpiaij, rows=24, cols=24
>  residual u = 1.60628e-06
>  residual p = 1.2094e-05
>  residual [u,p] = 1.22002e-05
>  discretization error u = 0.0106473
>  discretization error p = 1.85787
>  discretization error [u,p] = 1.8579
> ./ex70 -user_ksp -ksp_view
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Cannot locate function PCFieldSplitGetSubKSP_C in object
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.1, unknown
> [0]PETSC ERROR: ./ex70 on a darwin-gnu-fort-debug named
> gmbook.dhcp.lbnl.us by gbisht Fri Oct 31 09:28:38 2014
> [0]PETSC ERROR: Configure options -with-hdf5-dir=/opt/local/
> --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate
> --download-parmetis=yes --download-metis=yes --download-sundials=yes
> --with-mpich=/opt/local --with-cc=/opt/local/bin/mpicc-mpich-gcc48
> --with-cxx=/opt/local/bin/mpicxx-mpich-gcc48
> --with-fc=/opt/local/bin/mpifort-mpich-gcc48
> PETSC_ARCH=darwin-gnu-fort-debug --download-sowing=1
> [0]PETSC ERROR: #1 PCFieldSplitGetSubKSP() line 1637 in
> /Users/gbisht/Research/Models/PETSc/petsc3.5.1/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #2 StokesSetupPC() line 113 in
> /Users/gbisht/Research/Models/PETSc/petsc3.5.1/src/snes/examples/tutorials/ex70.c
> [0]PETSC ERROR: #3 main() line 686 in
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> Is my installation of PETSc incorrect? Would you suggest any particular
> starting examples that demonstrate how to use Schur complement as a
> preconditioner?
> Thanks,
> Gautam.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141031/7a41a066/attachment.html>
