[petsc-users] Error while running src/snes/examples/tutorials/ex70.c
Gautam Bisht gbisht at lbl.gov
Fri Oct 31 11:35:23 CDT 2014
I'm trying to learn how to use Schur complement as a preconditioner. I
ran src/snes/examples/tutorials/ex70.c for the two cases:
./ex70 -user_pc -ksp_view
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: none
  linear system matrix = precond matrix:
  Mat Object:   1 MPI processes
    type: nest
    rows=72, cols=72
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="a00_", type=mpiaij, rows=48, cols=48
        (0,1) : prefix="a01_", type=mpiaij, rows=48, cols=24
        (1,0) : prefix="a10_", type=mpiaij, rows=24, cols=48
        (1,1) : prefix="a11_", type=mpiaij, rows=24, cols=24
 residual u = 1.60628e-06
 residual p = 1.2094e-05
 residual [u,p] = 1.22002e-05
 discretization error u = 0.0106473
 discretization error p = 1.85787
 discretization error [u,p] = 1.8579
./ex70 -user_ksp -ksp_view
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Cannot locate function PCFieldSplitGetSubKSP_C in object
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.1, unknown
[0]PETSC ERROR: ./ex70 on a darwin-gnu-fort-debug named gmbook.dhcp.lbnl.us
by gbisht Fri Oct 31 09:28:38 2014
[0]PETSC ERROR: Configure options -with-hdf5-dir=/opt/local/
--with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate
--download-parmetis=yes --download-metis=yes --download-sundials=yes
--with-mpich=/opt/local --with-cc=/opt/local/bin/mpicc-mpich-gcc48
--with-cxx=/opt/local/bin/mpicxx-mpich-gcc48
--with-fc=/opt/local/bin/mpifort-mpich-gcc48
PETSC_ARCH=darwin-gnu-fort-debug --download-sowing=1
[0]PETSC ERROR: #1 PCFieldSplitGetSubKSP() line 1637 in
/Users/gbisht/Research/Models/PETSc/petsc3.5.1/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #2 StokesSetupPC() line 113 in
/Users/gbisht/Research/Models/PETSc/petsc3.5.1/src/snes/examples/tutorials/ex70.c
[0]PETSC ERROR: #3 main() line 686 in
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
Is my installation of PETSc incorrect? Would you suggest any particular
starting examples that demonstrate how to use Schur complement as a
preconditioner?
Gautam.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141031/1eb1392e/attachment.html>
