[petsc-users] Fwd: [dev at libelemental.org] Re: [elemental] Fwd: MatZeroRows and MATELEMENTAL
Jack Poulson jack.poulson at gmail.com
Tue Oct 28 00:20:29 CDT 2014
---------- Forwarded message ----------
Date: Mon, Oct 27, 2014 at 9:27 PM
Subject: [dev at libelemental.org] Re: [elemental] Fwd: [petsc-users]
To: "dev at libele >> Elemental" <dev at libelemental.org>, Matthew Knepley <
knepley at gmail.com>
Hi Matt,
At first glance, I would have suggested EntrywiseFill [1,2,3], which
takes an arbitrary function, say
    fill : (i,j) |-> T
and sets each entry (i,j) of a matrix of type T to fill(i,j), but the
documentation for MatZeroRows [4] states that only a subset of rows are
to be modified.
I would instead implement this as follows (in C++), for the slightly
more general case where the off-diagonal value can be arbitrary:
template<typename T>
void ModifyRows
( AbstractDistMatrix<T>& A, const std::vector<Int>& rowInd,
  T diagVal, T offDiagVal )
    DEBUG_ONLY(CallStackEntry cse("ModifyRows"))
    const Int numRows = rowInd.size();
    const Int localWidth = A.LocalWidth();
    for( Int s=0; s<numRows; ++s )
        const Int row = rowInd[s];
        if( A.IsLocalRow(row) )
            const Int iLoc = A.LocalRow(row);
            for( Int jLoc=0; jLoc<localWidth; ++jLoc )
                const Int j = A.GlobalCol(jLoc);
                if( i == j )
                    A.SetLocal( iLoc, jLoc, diagVal );
                else
                    A.SetLocal( iLoc, jLoc, offDiagVal );
If you are coming from C, one simply needs to convert the buffer into an
std::vector via
    std::vector<Int> rowInd(rows,rows+numRows);
Jack
P.S. The release candidate for 0.85 is coming in a few hours.
[1]
https://github.com/elemental/Elemental/blob/396a8cebc46ea13c4fbdc51a1f21fce2c1a75edf/include/El/blas_like/level1.hpp#L176
[2]
https://github.com/elemental/Elemental/blob/396a8cebc46ea13c4fbdc51a1f21fce2c1a75edf/include/El/blas_like/level1.h#L314
[3]
https://github.com/elemental/Elemental/blob/396a8cebc46ea13c4fbdc51a1f21fce2c1a75edf/include/El/blas_like/level1.py#L485
[4]
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatZeroRows.html
On 10/27/2014 02:36 PM, Matthew Knepley wrote:
> I do not know the answer to this one. Is there something in that does
> the equivalent of
> MatZeroRows(), or do you do it by hand?
>   Thanks,
>     Matt
> From: *Francesco Ballarin* <francesco.ballarin at polimi.it
> <mailto:francesco.ballarin at polimi.it>>
> Date: Sun, Oct 26, 2014 at 4:32 AM
> Subject: [petsc-users] MatZeroRows and MATELEMENTAL
> To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Dear PETSc users,
> I have a code for PETSc 3.3 in which the PLAPACK interface, now
> discontinued, was used. I am trying to update it to PETSc 3.5.2, using
> the Elemental interface.
> I see that MatZeroRows is not implemented for MATELEMENTAL. What
> function should I use instead? Does it also support the version with
> optional arguments x and b?
> Thanks,
> best regards,
> Francesco
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> You received this message because you are subscribed to the Google
> Groups "elemental-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send
> an email to elemental-dev+unsubscribe at googlegroups.com
> <mailto:elemental-dev+unsubscribe at googlegroups.com>.
> For more options, visit https://groups.google.com/d/optout.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/66dd7955/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/66dd7955/attachment.pgp>
