[petsc-users] How to use PETSc4py/SLEPc4py to solve an eigenvalue problem in parallel
Mengqi Zhang jollage at gmail.com
Sun Oct 26 11:10:07 CDT 2014
Dear all PETSc users,
I'm new to PETSc/SLEPc. And I'm currently trying to use
Python/PETSc4py/SLEPc4py to solve a big generalized eigenvalue problem, A x
= B lambda x.
After several days' digging and trying, I can write a script for solving a
smaller eigenvalue problem locally, but when the problem size increases, I
realize I should go parallel. My question is how to do it in parallel? How
could I preallocate the matrices among the processors? I presume there
should be a way to do that, but I couldn't find a clear guide on the
Internet.
Currently, the matrices are implemented locally, and then I use
E = SLEPc.EPS(); E.create()
E.setOperators(A,B)
E.setProblemType(SLEPc.EPS.ProblemType.GNHEP)
E.setFromOptions()
to locally solve the eigenvalue problem.
Could you help me and guide me to set the code up?  Any suggestion is
welcomed and appreciated. Thank you very much.
Best regards,
Mengqi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141026/86b2eee2/attachment.html>
