[petsc-users] TSSetIJacobian is never called
Mon Oct 27 13:13:59 CDT 2014
On Mon, Oct 27, 2014 at 1:11 PM, Sharp Stone <thronesf at gmail.com> wrote:
> Hi Matt,
> Thank you for your reply.
> That's why I am confused and need help. I set printf routines as I run my
> code, but it never output it on the screen.
Here is one point of confusion:
  1) TSSetIJacobian() sets a callback routine for creating the Jacobian.
This was definitely called
  2) FormIJacobian() is your function which I assume creates the Jacobian.
This is what I think you are saying is not called.
Not all TS solvers use a linear solve. Your first step is to run with
-ts_view so that we can see what solver is actually being used.
   Matt
> Thanks!
> On Mon, Oct 27, 2014 at 2:05 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Oct 27, 2014 at 1:02 PM, Sharp Stone <thronesf at gmail.com> wrote:
>>> Hi Matt,
>>> Thank you for your reply and sorry for the confusion.
>>> No. What I was trying to say is my code has never called the
>>> TSSetIJacobian() routine. I don't know why this happens, and how to resolve
>>> this either.
>> If your code has not called TSSetIJacobian(), I can only assume it is
>> because you did not put it in. However, in
>> the code fragment you sent, it was definitely there.
>>   Thanks,
>>     Matt
>>> Thank you in advance!
>>> On Mon, Oct 27, 2014 at 1:57 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Oct 27, 2014 at 12:52 PM, Sharp Stone <thronesf at gmail.com>
>>>> wrote:
>>>>> Dear All,
>>>>> I'm using the TS theta solver for backward Euler method. But I found
>>>>> that the TSSetIJacobian() routine has never been called. I did the code
>>>>> just following what the example does: src/ts/examples/tutorials/ex17. I can
>>>>> run the example without errors. But when I run my code, it won't be as good
>>>>> as the example as stated above. I also attached the piece of my setups to
>>>>> this email.
>>>>> How could I fix this problem? Thank you in advance!
>>>> I cannot understand the paragraph above.
>>>>   1) TS ex17 does call TSSetIJacobian(), unless you choose a
>>>> matrix-free version. You seem to imply above that it does not.
>>>>   2) Do you mean that you do not call it? You do not have too, since
>>>> you can use the finite difference approximations offered by SNES
>>>>   Thanks,
>>>>     Matt
>>>>>     TSCreate(PETSC_COMM_WORLD, &ts);
>>>>>     TSSetProblemType(ts, TS_NONLINEAR);
>>>>>     TSSetType(ts, TSTHETA);
>>>>>     TSThetaSetTheta(ts, 1.0);
>>>>>     TSSetIFunction(ts, NULL, FormIFunction, &appctx);
>>>>>     DMSetMatType(da, MATAIJ);
>>>>>     DMCreateMatrix(da, &J);
>>>>>     TSSetDM(ts, da);
>>>>>     TSSetIJacobian(ts, J, J, FormIJacobian, &appctx);
>>>>>     TSSetDuration(ts, timeStepsMax, Tend);
>>>>>     // Evaluate initial conditions
>>>>>     FormInitialSolution(&appctx);
>>>>>     TSSetSolution(ts, solution);
>>>>>     dt = 1.0;
>>>>>     TSSetInitialTimeStep(ts, 0.0, dt);
>>>>>     TSSolve(ts, solution);
>>>>> Best regards,
>>>>> Feng
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Best regards,
>>> Feng
>> experiments lead.
>> -- Norbert Wiener
> Best regards,
> Feng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/db66c56c/attachment.html>
