[petsc-users] TSSetIJacobian is never called
Sharp Stone thronesf at gmail.com
Mon Oct 27 13:11:05 CDT 2014
Hi Matt,
Thank you for your reply.
That's why I am confused and need help. I set printf routines as I run my
code, but it never output it on the screen.
Thanks!
On Mon, Oct 27, 2014 at 2:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 27, 2014 at 1:02 PM, Sharp Stone <thronesf at gmail.com> wrote:
>> Hi Matt,
>> Thank you for your reply and sorry for the confusion.
>> No. What I was trying to say is my code has never called the
>> TSSetIJacobian() routine. I don't know why this happens, and how to resolve
>> this either.
> If your code has not called TSSetIJacobian(), I can only assume it is
> because you did not put it in. However, in
> the code fragment you sent, it was definitely there.
>   Thanks,
>     Matt
>> Thank you in advance!
>> On Mon, Oct 27, 2014 at 1:57 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 27, 2014 at 12:52 PM, Sharp Stone <thronesf at gmail.com>
>>> wrote:
>>>> Dear All,
>>>> I'm using the TS theta solver for backward Euler method. But I found
>>>> that the TSSetIJacobian() routine has never been called. I did the code
>>>> just following what the example does: src/ts/examples/tutorials/ex17. I can
>>>> run the example without errors. But when I run my code, it won't be as good
>>>> as the example as stated above. I also attached the piece of my setups to
>>>> this email.
>>>> How could I fix this problem? Thank you in advance!
>>> I cannot understand the paragraph above.
>>>   1) TS ex17 does call TSSetIJacobian(), unless you choose a matrix-free
>>> version. You seem to imply above that it does not.
>>>   2) Do you mean that you do not call it? You do not have too, since you
>>> can use the finite difference approximations offered by SNES
>>>   Thanks,
>>>     Matt
>>>>     TSCreate(PETSC_COMM_WORLD, &ts);
>>>>     TSSetProblemType(ts, TS_NONLINEAR);
>>>>     TSSetType(ts, TSTHETA);
>>>>     TSThetaSetTheta(ts, 1.0);
>>>>     TSSetIFunction(ts, NULL, FormIFunction, &appctx);
>>>>     DMSetMatType(da, MATAIJ);
>>>>     DMCreateMatrix(da, &J);
>>>>     TSSetDM(ts, da);
>>>>     TSSetIJacobian(ts, J, J, FormIJacobian, &appctx);
>>>>     TSSetDuration(ts, timeStepsMax, Tend);
>>>>     // Evaluate initial conditions
>>>>     FormInitialSolution(&appctx);
>>>>     TSSetSolution(ts, solution);
>>>>     dt = 1.0;
>>>>     TSSetInitialTimeStep(ts, 0.0, dt);
>>>>     TSSolve(ts, solution);
>>>> Best regards,
>>>> Feng
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Best regards,
>> Feng
> experiments lead.
> -- Norbert Wiener
Best regards,
Feng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141027/07291904/attachment.html>
