[petsc-users] -log_view=:FILENAME:ascii_info_detail contains events with count 0
Wed Oct 22 14:59:46 CDT 2014
  I think the intention is that you write some simply python that processes the raw data dumped by the -log_view; so for example you could remove the events with count of 0. Would this work for you?
Barry
> On Oct 22, 2014, at 2:49 PM, Brad Aagaard <baagaard at usgs.gov> wrote:
> I noticed that when I use -log_view=:FILENAME:ascii_info_detail, I get a file that for each stage contains info for all events even when they are not called (count == 0). Is this the intended behavior? If so, is there a way to turn off output of information for events with count == 0?
> Thanks,
> Brad
