[petsc-users] -log_view=:FILENAME:ascii_info_detail contains events with count 0
Brad Aagaard baagaard at usgs.gov
Wed Oct 22 14:49:13 CDT 2014
I noticed that when I use -log_view=:FILENAME:ascii_info_detail, I get a
file that for each stage contains info for all events even when they are
not called (count == 0). Is this the intended behavior? If so, is there
a way to turn off output of information for events with count == 0?
Brad
