[petsc-users] Adaptive controllers in TS
Jed Brown jed at jedbrown.org
Mon Oct 20 23:42:25 CDT 2014
Miguel Angel Salazar de Troya <salazardetroya at gmail.com> writes:
> Thanks for your response
> I'm struggling with this problem because the literature is not clear for me
> on how to calculate the discrete adjoint with adaptive time stepping
> algorithms. They cover the details when automatic differentiation tools are
> used. They mention that because the time step depend on the solution, it
> also depends on the parameter. Hence, there are terms that represent the
> derivative of the time step w.r.t. the parameters. What it is confusing is
> that they mention these terms must be removed. I don't understand this. I'm
> planning to hard-code the discrete adjoint problem (and use the TS if
> possible).
Are they suggesting that the time step sizes for a given run should be
frozen (at least locally) so that you have consistent gradients for a
while?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/fc6695d9/attachment.pgp>
