[petsc-users] Error configuring with Ctetgen
Justin Chang jychang48 at gmail.com
Mon Oct 20 23:14:42 CDT 2014
Barry, I am not sure if this is what you're asking for (I am not too
familiar with gdb) but here's what happened after following your
instructions:
GNU gdb (GDB) 7.8
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-apple-darwin13.4.0".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./ex1...
warning: `/Users/jychang48/petsc-dev/src/vec/vec/examples/tutorials/ex1.o':
can't open to read symbols: No such file or directory.
(no debugging symbols found)...done.
(gdb) run
Starting program:
Unable to find Mach task port for process-id 57136: (os/kern) failure (0x5).
 (please check gdb is codesigned - see taskgated(8))
(gdb) bt carriage
No stack.
(gdb)
On Mon, Oct 20, 2014 at 10:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    cd src/vec/vec/examples/tutorials
>    make ex1
>    gdb ./ex1
>    run
>     if it stops type bt carriage return and send all the output
> > On Oct 20, 2014, at 10:37 PM, Justin Chang <jychang48 at gmail.com> wrote:
> > I did rm-rf arch-darwin-c-debug and ran config with the following
> options:
> > ./configure --download-exodusii --download-hdf5 --download-metis
> --download-mpich --download-mumps --download-netcdf --download-parmetis
> --download-scalapack --download-triangle --with-cc=gcc --with-cxx=g++
> --with-debugging=1 --with-fc=gfortran --with-valgrind=1 -with-cmake=cmake
> --download-ctetgen
> > And it compiles. However, once I run make all test I get the error
> "Attempting to use an MPI routine before initializing MPICH" when it
> attempts to run the test examples. Now I can't run any PETSc code
> whatsoever. Attached are the new make and configure log files.
> > Thanks,
> > Justin
> > On Mon, Oct 20, 2014 at 9:57 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Try:
> > rm -rf arch-darwin-c-debug
> > and rerun onfigure
> > [basically you have old version of ctetgen - and configure does not
> > have smarts to detect this or update to the appropriate version
> > automatically.  And its likely you have old versions of other packages
> > aswell - so its best to do a clean build]
> > BTW - you shouldn't need --download-fblaslapack on OSX [as it provides
> > -llapack -lblas via vecLib]
> > Satish
> > On Mon, 20 Oct 2014, Justin Chang wrote:
> > > Hi all,
> > > On my MacOSx I am trying to install the developer's version of petsc
> with
> > > the following options:
> > > ./configure --download-exodusii --download-fblaslapack --download-hdf5
> > > --download-metis --download-mpich --download-mumps --download-netcdf
> > > --download-parmetis --download-scalapack --download-triangle
> --with-cc=gcc
> > > --with-cxx=g++ --with-debugging=1 --with-fc=gfortran --with-valgrind=1
> > > -with-cmake=cmake --download-ctetgen
> > > The error I get is with the --download-ctetgen option
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > Error running make on Ctetgen: Could not execute "cd
> /Users/jychang48/petsc-dev/arch-darwin-c-debug/externalpackages/ctetgen &&
> > > /usr/bin/make PETSC_DIR=/Users/jychang48/petsc-dev install-ctetgen":
> > > make: *** No rule to make target `install-ctetgen'.  Stop.
> > > Do you guys know what is wrong? Attached are the make and log files.
> > > Thanks,
> > > Justin
> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/9906513e/attachment.html>
