[petsc-users] Error configuring with Ctetgen
Mon Oct 20 21:57:21 CDT 2014
Try:
rm -rf arch-darwin-c-debug
and rerun onfigure
[basically you have old version of ctetgen - and configure does not
have smarts to detect this or update to the appropriate version
automatically.  And its likely you have old versions of other packages
aswell - so its best to do a clean build]
BTW - you shouldn't need --download-fblaslapack on OSX [as it provides
-llapack -lblas via vecLib]
Satish
On Mon, 20 Oct 2014, Justin Chang wrote:
> Hi all,
> On my MacOSx I am trying to install the developer's version of petsc with
> the following options:
> ./configure --download-exodusii --download-fblaslapack --download-hdf5
> --download-metis --download-mpich --download-mumps --download-netcdf
> --download-parmetis --download-scalapack --download-triangle --with-cc=gcc
> --with-cxx=g++ --with-debugging=1 --with-fc=gfortran --with-valgrind=1
> -with-cmake=cmake --download-ctetgen
> The error I get is with the --download-ctetgen option
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running make on Ctetgen: Could not execute "cd
> /Users/jychang48/petsc-dev/arch-darwin-c-debug/externalpackages/ctetgen &&
> /usr/bin/make PETSC_DIR=/Users/jychang48/petsc-dev install-ctetgen":
> make: *** No rule to make target `install-ctetgen'.  Stop.
> Do you guys know what is wrong? Attached are the make and log files.
> Thanks,
> Justin
