[petsc-users] Error configuring with Ctetgen
Justin Chang jychang48 at gmail.com
Mon Oct 20 21:48:11 CDT 2014
Hi all,
On my MacOSx I am trying to install the developer's version of petsc with
the following options:
./configure --download-exodusii --download-fblaslapack --download-hdf5
--download-metis --download-mpich --download-mumps --download-netcdf
--download-parmetis --download-scalapack --download-triangle --with-cc=gcc
--with-cxx=g++ --with-debugging=1 --with-fc=gfortran --with-valgrind=1
-with-cmake=cmake --download-ctetgen
The error I get is with the --download-ctetgen option
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error running make on Ctetgen: Could not execute "cd
/Users/jychang48/petsc-dev/arch-darwin-c-debug/externalpackages/ctetgen &&
/usr/bin/make PETSC_DIR=/Users/jychang48/petsc-dev install-ctetgen":
make: *** No rule to make target `install-ctetgen'.  Stop.
Do you guys know what is wrong? Attached are the make and log files.
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/5af8d404/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/5af8d404/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141020/5af8d404/attachment-0003.obj>
