[petsc-users] petsc git next branch *is* unwound!
Thu Oct 2 11:08:28 CDT 2014
Sorry - perhaps the instructions should have been:
git checkout master
git branch -D next
git fetch
git checkout next
Satish
On Thu, 2 Oct 2014, Barry Smith wrote:
>   Why does it say "Already up-to-date.”  ? It’s like those things are already in next? Why isn’t it putting a bunch of stuff into next? Confusing
>    Barry
> ~/Src/petsc  next $ git checkout master
> Switched to branch 'master'
> Your branch is behind 'origin/master' by 3 commits, and can be fast-forwarded.
>   (use "git pull" to update your local branch)
> ~/Src/petsc  master $ git branch -D next
> Deleted branch next (was 5fad734).
> ~/Src/petsc  master $ git checkout next
> Branch next set up to track remote branch next from origin.
> Switched to a new branch 'next'
> ~/Src/petsc  next $ git pull
> From bitbucket.org:petsc/petsc
>  + 5fad734...6e2aac5 next       -> origin/next  (forced update)
>  * [new branch]      next-oct-2014 -> origin/next-oct-2014
> Already up-to-date!
> Merge made by the 'recursive' strategy.
> ~/Src/petsc  next $ git merge barry/cleanup-blaslapack
> Already up-to-date.
> ~/Src/petsc  next $ git merge barry/remove-dreal
> Already up-to-date.
> ~/Src/petsc  next $ git merge barry/remove-sidl
> Already up-to-date.
> ~/Src/petsc  next $ git merge barry/reuse-hwloc
> Already up-to-date.
> ~/Src/petsc  next $ git push
> Counting objects: 1, done.
> Writing objects: 100% (1/1), 248 bytes | 0 bytes/s, done.
> Total 1 (delta 0), reused 0 (delta 0)
> To git at bitbucket.org:petsc/petsc.git
>    6e2aac5..8c34c3a  next -> next
> On Oct 2, 2014, at 8:16 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > petsc git users,
> > If you are using next branch from git repository for integration or
> > testing or working with it in some form - i.e if you have 'next'
> > listed by:
> > git branch
> > Please delete and recreate it. i.e:
> > git checkout master
> > git branch -D next
> > git checkout next
> > From my check - the following feature branches are currently in next
> > (not yet merged to master).
> > Feature branch owners, please remerge your feature branches into to
> > next - as you see fit.
> > $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
> >  origin/barry/cleanup-blaslapack
> >  origin/barry/remove-dreal
> >  origin/barry/remove-sidl
> >  origin/barry/reuse-hwloc
> >  origin/dmeiser/pullrequest-fix-cusp-bjacobi2
> >  origin/dmeiser/pullrequest-remove-thrust-py
> >  origin/jed/sr-driver4
> >  origin/jed/vecghostgetvalues
> >  origin/karlrupp/fix-viennacl-veccopy
> >  origin/karpeev/fix-ksp-pcgasm
> >  origin/knepley/feature-optcontrol-mg
> >  origin/knepley/feature-plex-generator-args
> >  origin/knepley/feature-plex-nasm
> >  origin/knepley/fix-configure-petsc-dep
> >  origin/knepley/fix-quadrature-order
> >  origin/madams/sr-driver4
> >  origin/maint
> >  origin/mlange05/fix-gmsh-coordinates
> >  origin/next
> >  origin/paulmullowney/aijcusp-ellpack-fix
> >  origin/prbrune/sf-examplefix
> >  origin/prbrune/snes-ex19vtkoutput
> >  origin/sarich/fix-tao-jbearing-bqpip
> >  origin/shri/ts-dae-semi-explicit
> >  origin/shri/ts-is-for-differential-variables
> >  origin/shri/ts-powergrid
> >  origin/stefano_zampini/matis-preallocation
> >  origin/stefano_zampini/pcbddc-changeofbasis
> >  origin/stefano_zampini/pcbddc_deluxe
> >  origin/tisaac/feature-fe-geom-dim
> >  origin/tisaac/plex-flexible-projection
> > [obviously remove maint, next from the above list]
> > The previous 'next' branch is currently available as 'next-oct-2014' -
> > if you need it for any checks/debugging.
> > Satish
