[petsc-users] petsc git next branch *is* unwound!
Thu Oct 2 11:05:37 CDT 2014
  Why does it say "Already up-to-date.”  ? It’s like those things are already in next? Why isn’t it putting a bunch of stuff into next? Confusing
   Barry
~/Src/petsc  next $ git checkout master
Switched to branch 'master'
Your branch is behind 'origin/master' by 3 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
~/Src/petsc  master $ git branch -D next
Deleted branch next (was 5fad734).
~/Src/petsc  master $ git checkout next
Branch next set up to track remote branch next from origin.
Switched to a new branch 'next'
~/Src/petsc  next $ git pull
From bitbucket.org:petsc/petsc
 + 5fad734...6e2aac5 next       -> origin/next  (forced update)
 * [new branch]      next-oct-2014 -> origin/next-oct-2014
Already up-to-date!
Merge made by the 'recursive' strategy.
~/Src/petsc  next $ git merge barry/cleanup-blaslapack
Already up-to-date.
~/Src/petsc  next $ git merge barry/remove-dreal
Already up-to-date.
~/Src/petsc  next $ git merge barry/remove-sidl
Already up-to-date.
~/Src/petsc  next $ git merge barry/reuse-hwloc
Already up-to-date.
~/Src/petsc  next $ git push
Counting objects: 1, done.
Writing objects: 100% (1/1), 248 bytes | 0 bytes/s, done.
Total 1 (delta 0), reused 0 (delta 0)
To git at bitbucket.org:petsc/petsc.git
   6e2aac5..8c34c3a  next -> next
On Oct 2, 2014, at 8:16 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> petsc git users,
> If you are using next branch from git repository for integration or
> testing or working with it in some form - i.e if you have 'next'
> listed by:
> git branch
> Please delete and recreate it. i.e:
> git checkout master
> git branch -D next
> git checkout next
> From my check - the following feature branches are currently in next
> (not yet merged to master).
> Feature branch owners, please remerge your feature branches into to
> next - as you see fit.
> $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
>  origin/barry/cleanup-blaslapack
>  origin/barry/remove-dreal
>  origin/barry/remove-sidl
>  origin/barry/reuse-hwloc
>  origin/dmeiser/pullrequest-fix-cusp-bjacobi2
>  origin/dmeiser/pullrequest-remove-thrust-py
>  origin/jed/sr-driver4
>  origin/jed/vecghostgetvalues
>  origin/karlrupp/fix-viennacl-veccopy
>  origin/karpeev/fix-ksp-pcgasm
>  origin/knepley/feature-optcontrol-mg
>  origin/knepley/feature-plex-generator-args
>  origin/knepley/feature-plex-nasm
>  origin/knepley/fix-configure-petsc-dep
>  origin/knepley/fix-quadrature-order
>  origin/madams/sr-driver4
>  origin/maint
>  origin/mlange05/fix-gmsh-coordinates
>  origin/next
>  origin/paulmullowney/aijcusp-ellpack-fix
>  origin/prbrune/sf-examplefix
>  origin/prbrune/snes-ex19vtkoutput
>  origin/sarich/fix-tao-jbearing-bqpip
>  origin/shri/ts-dae-semi-explicit
>  origin/shri/ts-is-for-differential-variables
>  origin/shri/ts-powergrid
>  origin/stefano_zampini/matis-preallocation
>  origin/stefano_zampini/pcbddc-changeofbasis
>  origin/stefano_zampini/pcbddc_deluxe
>  origin/tisaac/feature-fe-geom-dim
>  origin/tisaac/plex-flexible-projection
> [obviously remove maint, next from the above list]
> The previous 'next' branch is currently available as 'next-oct-2014' -
> if you need it for any checks/debugging.
> Satish
