[petsc-users] running error
Jed Brown jed at jedbrown.org
Sun Nov 30 21:28:50 CST 2014
Please keep the discussion on-list.
paul zhang <paulhuaizhang at gmail.com> writes:
> I set some breakpoints, which shows the code breaks down at the
> PetscInitialize(&argc,&argv,(char *)0,help);
Run in a debugger and send a stack trace.  This is most likely due to a
misconfigured environment/MPI.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141130/a368c899/attachment.pgp>
