[petsc-users] running error
Jed Brown jed at jedbrown.org
Sun Nov 30 21:01:39 CST 2014
paul zhang <paulhuaizhang at gmail.com> writes:
> Hello,
> I compiled the newest version of  petsc-3.5.2 and tried to test an example
> code with it. I could managed the compilation, but as I ran the sample,
> some error popped out.  Could you please have a check? (files attached. I
> did search the issue online, but ends up with no valid solution.)
> Error obtaining unique transport key from ORTE
> (orte_precondition_transports not present in
> the environment).
Looks like an Open MPI/resource manager configuration issue.  This
thread has a workaround, but your facility should be notified so that
they can provide a system-wide fix.
http://comments.gmane.org/gmane.comp.clustering.open-mpi.user/14871
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141130/3fb0b5c5/attachment.pgp>
