[petsc-users] petsc-3.5.2: ex12 with Neumann BC
Thu Nov 27 07:44:29 CST 2014
On Thu, Nov 27, 2014 at 7:06 AM, Olivier Bonnefon <
olivier.bonnefon at avignon.inra.fr> wrote:
>  Hello,
> Thanks you, it works. If I remove the NullSpaceCondition I get the correct
> solution also with Neumann BC.
> From my point of view, the linear system I get is not singular because
> there is a unique solution. Do you agree ?
Yes, the non-uniqueness is for the Poisson prblem only.
     Matt
> Regards,
> Olivier Bonnefon
> On 11/25/2014 03:01 PM, Matthew Knepley wrote:
>  On Tue, Nov 25, 2014 at 4:08 AM, Olivier Bonnefon <
>>  Hello,
>> Thank you for your answer, I agree with you.
>> I have adapted the ex12 example for the system:
>> -\nabla \nabla u + u + f = 0 in \Omega  (1)
>> with f = 4-x^2-y^2
>> The solution is still x^2-y^2.
>> It consists in adding the following gradient function:
>> void g0_uu(const PetscScalar u[], const PetscScalar u_t[], const
>> PetscScalar u_x[], const PetscScalar a[], const PetscScalar a_t[], const
>> PetscScalar a_x[], const PetscReal x[], PetscScalar g0[])
>>   g0[0] = 1.0;
>> //and set gradient
>> ierr = PetscDSSetJacobian(prob, 0, 0, g0_uu, NULL, NULL,
>> g3_uu);CHKERRQ(ierr);
>> Of course, I have modified the f0_u function.
>> With Dirichlet BC, I get the solution.
>> With Neumann BC, the solution is still shifted down (-2/3). The problem
>> (1) with Neumann BC has a unique solution.
>> How remove the condition \int_\Omega u = 0 ?
>  That condition is one way of imposing boundary conditions for pressure.
> When I call MatSetNullSpace(), I am implying
> this condition. You can take out that call, but the system will be
> singular. You would have to add a condition on the
> pressure somehow, like fixing it at a point. This tends to make the system
> more ill-conditioned, but if that is appropriate
> for you, then you make a similar call to
>        ierr = DMPlexAddBoundary(cdm, user->bcType == DIRICHLET, "wall",
> user->bcType == NEUMANN ? "boundary" : "marker", 0, user->exactFuncs[0], 1,
> &id, user);CHKERRQ(ierr);
>  but for field 1. To test , you can jsut change 0 to 1 in this call.
> However, this sets the entire boundary, and you really only
> need to set the pressure at one point, so you could make another label
> that only has a single point and use that instead.
>    Thanks,
>       Matt
>>  Thanks
>> Olivier Bonnefon
>> On 11/06/2014 07:14 AM, Matthew Knepley wrote:
>>  On Mon, Nov 3, 2014 at 9:46 AM, Olivier Bonnefon <
>>>  Hello,
>>> Thank for your answer, I'll explain my trouble:
>>> My problem is that the BC Neumann leads to wrong result.
>>> With Dirichlet BC, I get:
>>> > ./ex12 -run_type full -refinement_limit 0.0    -bc_type dirichlet
>>> -interpolate 0 -petscspace_order 1 -show_initial -show_solution
>>> -dm_plex_print_fem 1
>>> Solution
>>> Vec Object:potential 1 MPI processes
>>>   type: seq
>>> 0.5
>>> This result is correct.
>>> With Neuman BC, I get:
>>> > ./ex12 -run_type full -refinement_limit 0.0    -bc_type neumann
>>> -interpolate 1 -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>> -show_solution -bd_petscspace_order 1 -snes_linesearch_monitor
>>> -snes_monitor -ksp_monitor_true_residual -snes_converged_reason
>>> -ksp_converged_reason
>>> Solution
>>>   type: seq
>>> -0.75
>>> -0.583333
>>> 0.0833333
>>> -0.583333
>>> -0.333333
>>> 0.416667
>>> 0.0833333
>>> 0.416667
>>> 1.25
>>> That is not the values of the solution x*x+y*y.
>>  Sorry, this is poor documentation on my part. I will fix it in the
>> example. The Naumann solution
>> explicitly discards the constant part, meaning
>>    \int_\Omega u = 0
>>  If we look at my solution
>>    \int^1_0 dx \int^1_0 dy x^2 + y^2 = 2/3
>>  However, this is for the continuum result, whereas we are enforcing
>> this in the discrete case.
>> Thus, what we really get is 0.75, since we are integrating linear patches
>> instead of quadratic
>> patches. After shifting by that, you still do not get exactly x^2 + y^2
>> since there is some
>> discretization error. If you run with P2 you should get the exact answer,
>> shifted down to eliminate
>> the DC component.
>>    Thanks,
>>       Matt
>>> I tried many ksp options.
>>> Moreover, the neumann BC with "-run_type full" is not cover in the list
>>> https://bitbucket.org/petsc/petsc/src/fced3c3f9e703542693913793d15321603e40fe6/config/builder.py?at=master#cl-257
>>> Do you know what is wrong ?
>>> Thanks,
>>> Olivier Bonnefon
>>> On 10/31/2014 06:50 PM, Matthew Knepley wrote:
>>>  On Fri, Oct 31, 2014 at 10:43 AM, Olivier Bonnefon <
>>>> Hello,
>>>> I'm working on the snes/examples/tutorial/ex12 version 3.5.2.
>>>> I didn't succed to run the simplest case with Neumann BC:
>>>> This leads to dofs negatives values.
>>>  I do not understand what you mean. Please always mail the full error
>>> message.
>>>> Do you know the options to get a correct result with Neumann BC ?
>>>  There are some tests here:
>>>     Matt
>>>> Regards,
>>>> Olivier Bonnefon
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> Olivier Bonnefon
>>> INRA PACA-Avignon, Unité BioSP
>>> Tel: +33 (0)4 32 72 21 58
>> experiments lead.
>> -- Norbert Wiener
>> Olivier Bonnefon
> experiments lead.
> -- Norbert Wiener
> Olivier Bonnefon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141127/c0fee150/attachment.html>
