[petsc-users] petsc-3.5.2: ex12 with Neumann BC
Olivier Bonnefon olivier.bonnefon at avignon.inra.fr
Thu Nov 27 07:06:58 CST 2014
Hello,
Thanks you, it works. If I remove the NullSpaceCondition I get the
correct solution also with Neumann BC.
 From my point of view, the linear system I get is not singular because
there is a unique solution. Do you agree ?
Olivier Bonnefon
On 11/25/2014 03:01 PM, Matthew Knepley wrote:
> On Tue, Nov 25, 2014 at 4:08 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr
> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
>     Hello,
>     Thank you for your answer, I agree with you.
>     I have adapted the ex12 example for the system:
>     -\nabla \nabla u + u + f = 0 in \Omega  (1)
>     with f = 4-x^2-y^2
>     The solution is still x^2-y^2.
>     It consists in adding the following gradient function:
>     void g0_uu(const PetscScalar u[], const PetscScalar u_t[], const
>     PetscScalar u_x[], const PetscScalar a[], const PetscScalar a_t[],
>     const PetscScalar a_x[], const PetscReal x[], PetscScalar g0[])
>       g0[0] = 1.0;
>     //and set gradient
>     ierr = PetscDSSetJacobian(prob, 0, 0, g0_uu, NULL, NULL,
>     g3_uu);CHKERRQ(ierr);
>     Of course, I have modified the f0_u function.
>     With Dirichlet BC, I get the solution.
>     With Neumann BC, the solution is still shifted down (-2/3). The
>     problem (1) with Neumann BC has a unique solution.
>     How remove the condition \int_\Omega u = 0 ?
> That condition is one way of imposing boundary conditions for
> pressure. When I call MatSetNullSpace(), I am implying
> this condition. You can take out that call, but the system will be
> singular. You would have to add a condition on the
> pressure somehow, like fixing it at a point. This tends to make the
> system more ill-conditioned, but if that is appropriate
> for you, then you make a similar call to
>       ierr = DMPlexAddBoundary(cdm, user->bcType == DIRICHLET, "wall",
> user->bcType == NEUMANN ? "boundary" : "marker", 0,
> user->exactFuncs[0], 1, &id, user);CHKERRQ(ierr);
> but for field 1. To test , you can jsut change 0 to 1 in this call.
> However, this sets the entire boundary, and you really only
> need to set the pressure at one point, so you could make another label
> that only has a single point and use that instead.
>   Thanks,
>      Matt
>     Thanks
>     Olivier Bonnefon
>     On 11/06/2014 07:14 AM, Matthew Knepley wrote:
>>     On Mon, Nov 3, 2014 at 9:46 AM, Olivier Bonnefon
>>         Hello,
>>         Thank for your answer, I'll explain my trouble:
>>         My problem is that the BC Neumann leads to wrong result.
>>         With Dirichlet BC, I get:
>>         > ./ex12 -run_type full -refinement_limit 0.0    -bc_type
>>         dirichlet -interpolate 0 -petscspace_order 1 -show_initial
>>         -show_solution -dm_plex_print_fem 1
>>         Solution
>>         Vec Object:potential 1 MPI processes
>>           type: seq
>>         0.5
>>         This result is correct.
>>         With Neuman BC, I get:
>>         neumann -interpolate 1 -petscspace_order 1 -show_initial
>>         -dm_plex_print_fem 1 -show_solution -bd_petscspace_order 1
>>         -snes_linesearch_monitor -snes_monitor
>>         -ksp_monitor_true_residual -snes_converged_reason
>>         -ksp_converged_reason
>>         Solution
>>           type: seq
>>         -0.75
>>         -0.583333
>>         0.0833333
>>         -0.583333
>>         -0.333333
>>         0.416667
>>         0.0833333
>>         0.416667
>>         1.25
>>         That is not the values of the solution x*x+y*y.
>>     Sorry, this is poor documentation on my part. I will fix it in
>>     the example. The Naumann solution
>>     explicitly discards the constant part, meaning
>>       \int_\Omega u = 0
>>     If we look at my solution
>>       \int^1_0 dx \int^1_0 dy x^2 + y^2 = 2/3
>>     However, this is for the continuum result, whereas we are
>>     enforcing this in the discrete case.
>>     Thus, what we really get is 0.75, since we are integrating linear
>>     patches instead of quadratic
>>     patches. After shifting by that, you still do not get exactly x^2
>>     + y^2 since there is some
>>     discretization error. If you run with P2 you should get the exact
>>     answer, shifted down to eliminate
>>     the DC component.
>>       Thanks,
>>          Matt
>>         I tried many ksp options.
>>         Moreover, the neumann BC with "-run_type full" is not cover
>>         in the list
>>         https://bitbucket.org/petsc/petsc/src/fced3c3f9e703542693913793d15321603e40fe6/config/builder.py?at=master#cl-257
>>         Do you know what is wrong ?
>>         Thanks,
>>         Olivier Bonnefon
>>         On 10/31/2014 06:50 PM, Matthew Knepley wrote:
>>>         On Fri, Oct 31, 2014 at 10:43 AM, Olivier Bonnefon
>>>             Hello,
>>>             I'm working on the snes/examples/tutorial/ex12 version
>>>             3.5.2.
>>>             I didn't succed to run the simplest case with Neumann BC:
>>>             1 -snes_linesearch_monitor -snes_monitor
>>>             This leads to dofs negatives values.
>>>         I do not understand what you mean. Please always mail the
>>>         full error message.
>>>             Do you know the options to get a correct result with
>>>             Neumann BC ?
>>>         There are some tests here:
>>>            Matt
>>>             Regards,
>>>             Olivier Bonnefon
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>         Olivier Bonnefon
>>         INRA PACA-Avignon, Unité BioSP
>>         Tel:+33 (0)4 32 72 21 58  <tel:%2B33%20%280%294%2032%2072%2021%2058>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
>     Olivier Bonnefon
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Olivier Bonnefon
Tel: +33 (0)4 32 72 21 58
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141127/9f1e4505/attachment-0001.html>
