[petsc-users] Error while calling a fieldsplit preconditioner containing a mg/gamg preconditioner
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Fri Nov 21 11:08:51 CST 2014
> On 21 Nov 2014, at 16:55, Luc Berger-Vergiat <lb2653 at columbia.edu> wrote:
> Sure, so with gamg (which was my first choice too), I get the following:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR:
> [0]PETSC ERROR: Must call DMShellSetGlobalVector() or         DMShellSetCreateGlobalVector()
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
> [0]PETSC ERROR: /home/luc/research/feap_repo/ShearBands/parfeap/feap on a arch-opt named euler by
I wonder if this is the same problem described here https://bitbucket.org/petsc/petsc/pull-request/221
Where the ksp contains an inactive dmshell that doesn't know how to create vectors
Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141121/28fe2b7c/attachment.html>
