[petsc-users] Error while calling a fieldsplit preconditioner containing a mg/gamg preconditioner
Fri Nov 21 10:14:08 CST 2014
On Fri, Nov 21, 2014 at 9:55 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>
wrote:
>  Hi all,
> I am using a DMShell to create to use a fieldsplit preconditioner.
> I would like to try some of petsc's multigrid options: mg and gamg.
Lets start with gamg, since that does not need anything else from the user.
If you want to use mg,
then you will need to supply the interpolation/restriction operators since
we cannot calculate them
without an idea of the discretization.
     Matt
> When I call my preconditioner:
> -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type schur
> -pc_fieldsplit_schur_factorization_type full
> -pc_fieldsplit_schur_precondition selfp -pc_fieldsplit_0_fields 2,3
> -pc_fieldsplit_1_fields 0,1 -fieldsplit_0_ksp_type preonly
> -fieldsplit_0_pc_type hypre -fieldsplit_0_pc_hypre_type euclid
> -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type mg -malloc_log mlog
> -log_summary time.log -ksp_view
> it returns me the following error message and ksp_view:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR:
> [0]PETSC ERROR: Must call DMShellSetGlobalVector() or
> DMShellSetCreateGlobalVector()
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
> [0]PETSC ERROR: /home/luc/research/feap_repo/ShearBands/parfeap/feap on a
> arch-opt named euler by luc Fri Nov 21 10:12:53 2014
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
> --with-cxx=g++ --with-debugging=0 --with-shared-libraries=0
> --download-fblaslapack --download-mpich --download-parmetis
> --download-metis --download-ml=yes --download-hypre --download-superlu_dist
> --download-mumps --download-scalapack
> [0]PETSC ERROR: #259 DMCreateGlobalVector_Shell() line 245 in
> /home/luc/research/petsc-3.5.2/src/dm/impls/shell/dmshell.c
> [0]PETSC ERROR: #260 DMCreateGlobalVector() line 681 in
> /home/luc/research/petsc-3.5.2/src/dm/interface/dm.c
> [0]PETSC ERROR: #261 DMGetGlobalVector() line 154 in
> /home/luc/research/petsc-3.5.2/src/dm/interface/dmget.c
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization FULL
>     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (the lumped) A00's diagonal's inverse
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>         type: preonly
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>         using NONE norm type for convergence test
>       PC Object:      (fieldsplit_0_)       1 MPI processes
>         type: hypre
>           HYPRE Euclid preconditioning
>           HYPRE Euclid: number of levels 1
>         linear system matrix = precond matrix:
>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>           type: seqaij
>           rows=2000, cols=2000
>           total: nonzeros=40000, allocated nonzeros=40000
>           total number of mallocs used during MatSetValues calls =0
>             using I-node routines: found 400 nodes, limit used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_1_)       1 MPI processes
>         type: mg
>           MG: type is MULTIPLICATIVE, levels=1 cycles=v
>             Cycles per PCApply=1
>             Not using Galerkin computed coarse grid matrices
>         Coarse grid solver -- level -------------------------------
>           KSP Object:          (fieldsplit_1_mg_levels_0_)           1 MPI
> processes
>             type: chebyshev
>               Chebyshev: eigenvalue estimates:  min = 1.70057, max =
> 18.7063
>               Chebyshev: estimated using:  [0 0.1; 0 1.1]
>               KSP Object:
> (fieldsplit_1_mg_levels_0_est_)               1 MPI processes
>                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
>                 maximum iterations=10, initial guess is zero
> divergence=10000
>               PC Object:
> (fieldsplit_1_mg_levels_0_)               1 MPI processes
>                 type: sor
>                   SOR: type = local_symmetric, iterations = 1, local
> iterations = 1, omega = 1
>                 linear system matrix followed by preconditioner matrix:
>                 Mat Object:                (fieldsplit_1_)
> 1 MPI processes
>                   type: schurcomplement
>                   rows=330, cols=330
>                     Schur complement A11 - A10 inv(A00) A01
>                     A11
>                       Mat Object:
>                         type: seqaij
>                         rows=330, cols=330
>                         total: nonzeros=7642, allocated nonzeros=7642
> calls =0
>                           using I-node routines: found 121 nodes, limit
> used is 5
>                     A10
>                       Mat Object:                       1 MPI processes
>                         type: seqaij
>                         rows=330, cols=2000
>                         total: nonzeros=22800, allocated nonzeros=22800
> calls =0
> used is 5
>                     KSP of A00
>                       KSP Object:
>                         type: preonly
> divergence=10000
>                       PC Object:
>                         type: hypre
>                         Mat Object:
>                           type: seqaij
> calls =0
> used is 5
>                     A01
>                         type: seqaij
>                         rows=2000, cols=330
> calls =0
> used is 5
>                   type: seqaij
>                   rows=330, cols=330
>                     using I-node routines: found 121 nodes, limit used is 5
>             maximum iterations=1, initial guess is zero
>           PC Object:          (fieldsplit_1_mg_levels_0_)           1 MPI
> processes
>             type: sor
>             Mat Object:            (fieldsplit_1_)             1 MPI
> processes
>               rows=330, cols=330
>                 A11
>                   Mat Object:
>                     type: seqaij
>                     rows=330, cols=330
> =0
> is 5
>                 A10
>                     type: seqaij
>                     rows=330, cols=2000
> =0
> is 5
>                 KSP of A00
>                   KSP Object:
>                     type: preonly
> divergence=10000
>                   PC Object:
>                     type: hypre
>                     Mat Object:
>                       type: seqaij
> calls =0
> is 5
>                 A01
>                     type: seqaij
>                     rows=2000, cols=330
> =0
> is 5
>               type: seqaij
>               rows=330, cols=330
>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>           rows=330, cols=330
>             A11
> processes
>                 type: seqaij
>                 rows=330, cols=330
>             A10
>                 type: seqaij
>                 rows=330, cols=2000
>             KSP of A00
> processes
>                 type: preonly
> divergence=10000
> processes
>                 type: hypre
> 1 MPI processes
>                   type: seqaij
>             A01
>                 type: seqaij
>                 rows=2000, cols=330
>           type: seqaij
>           rows=330, cols=330
>     type: seqaij
>     rows=2330, cols=2330
>     total: nonzeros=93242, allocated nonzeros=93242
>       using I-node routines: found 521 nodes, limit used is 5
> I am not completely surprised by this since the multigrid algorithm might
> want to know the structure of my vector in order to do a good job at
> restrictions and prolongations, etc... I am just not sure when I should
> call: DMShellSetGlobalVector() or DMShellSetCreateGlobalVector().
> If I call DMShellSetGlobalVector() I assume that I need to generate my
> vector somehow before hand but I don't know what is required to make it a
> valid "template" vector?
> If I call DMShellSetCreateGlobalVector() I need to pass it a functions
> that computes a vector but what kind of vector? A residual or a "template"?
> This is not very clear to me...
> Best,
> Luc
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141121/ae5604c0/attachment-0001.html>
