[petsc-users] Error while calling a fieldsplit preconditioner containing a mg/gamg preconditioner
Luc Berger-Vergiat lb2653 at columbia.edu
Fri Nov 21 09:55:57 CST 2014
Hi all,
I am using a DMShell to create to use a fieldsplit preconditioner.
I would like to try some of petsc's multigrid options: mg and gamg.
When I call my preconditioner:
    -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type schur
    -pc_fieldsplit_schur_factorization_type full
    -pc_fieldsplit_schur_precondition selfp -pc_fieldsplit_0_fields 2,3
    -pc_fieldsplit_1_fields 0,1 -fieldsplit_0_ksp_type preonly
    -fieldsplit_0_pc_type hypre -fieldsplit_0_pc_hypre_type euclid
    -fieldsplit_1_ksp_type gmres -fieldsplit_1_pc_type mg -malloc_log
    mlog -log_summary time.log -ksp_view
it returns me the following error message and ksp_view:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR:
[0]PETSC ERROR: Must call DMShellSetGlobalVector() or
DMShellSetCreateGlobalVector()
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
[0]PETSC ERROR: /home/luc/research/feap_repo/ShearBands/parfeap/feap on
a arch-opt named euler by luc Fri Nov 21 10:12:53 2014
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
--with-cxx=g++ --with-debugging=0 --with-shared-libraries=0
--download-fblaslapack --download-mpich --download-parmetis
--download-metis --download-ml=yes --download-hypre
--download-superlu_dist --download-mumps --download-scalapack
[0]PETSC ERROR: #259 DMCreateGlobalVector_Shell() line 245 in
/home/luc/research/petsc-3.5.2/src/dm/impls/shell/dmshell.c
[0]PETSC ERROR: #260 DMCreateGlobalVector() line 681 in
/home/luc/research/petsc-3.5.2/src/dm/interface/dm.c
[0]PETSC ERROR: #261 DMGetGlobalVector() line 154 in
/home/luc/research/petsc-3.5.2/src/dm/interface/dmget.c
KSP Object: 1 MPI processes
   type: gmres
     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     GMRES: happy breakdown tolerance 1e-30
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
   left preconditioning
   using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
   type: fieldsplit
     FieldSplit with Schur preconditioner, factorization FULL
     Preconditioner for the Schur complement formed from Sp, an
assembled approximation to S, which uses (the lumped) A00's diagonal's
inverse
     Split info:
     Split number 0 Defined by IS
     Split number 1 Defined by IS
     KSP solver for A00 block
       KSP Object:      (fieldsplit_0_)       1 MPI processes
         type: preonly
         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
         using NONE norm type for convergence test
       PC Object:      (fieldsplit_0_)       1 MPI processes
         type: hypre
           HYPRE Euclid preconditioning
           HYPRE Euclid: number of levels 1
         linear system matrix = precond matrix:
         Mat Object:        (fieldsplit_0_)         1 MPI processes
           type: seqaij
           rows=2000, cols=2000
           total: nonzeros=40000, allocated nonzeros=40000
           total number of mallocs used during MatSetValues calls =0
             using I-node routines: found 400 nodes, limit used is 5
     KSP solver for S = A11 - A10 inv(A00) A01
       KSP Object:      (fieldsplit_1_)       1 MPI processes
         type: gmres
       PC Object:      (fieldsplit_1_)       1 MPI processes
         type: mg
           MG: type is MULTIPLICATIVE, levels=1 cycles=v
             Cycles per PCApply=1
             Not using Galerkin computed coarse grid matrices
         Coarse grid solver -- level -------------------------------
           KSP Object: (fieldsplit_1_mg_levels_0_)           1 MPI processes
             type: chebyshev
               Chebyshev: eigenvalue estimates:  min = 1.70057, max =
18.7063
               Chebyshev: estimated using:  [0 0.1; 0 1.1]
               KSP Object: (fieldsplit_1_mg_levels_0_est_)
1 MPI processes
                 type: gmres
Gram-Schmidt Orthogonalization with no iterative refinement
                 maximum iterations=10, initial guess is zero
divergence=10000
               PC Object: (fieldsplit_1_mg_levels_0_)               1
MPI processes
                 type: sor
                   SOR: type = local_symmetric, iterations = 1, local
iterations = 1, omega = 1
                 linear system matrix followed by preconditioner matrix:
                 Mat Object: (fieldsplit_1_)                 1 MPI processes
                   type: schurcomplement
                   rows=330, cols=330
                     Schur complement A11 - A10 inv(A00) A01
                     A11
1 MPI processes
                         type: seqaij
                         rows=330, cols=330
                         total: nonzeros=7642, allocated nonzeros=7642
                           using I-node routines: found 121 nodes, limit
used is 5
                     A10
                       Mat Object:                       1 MPI processes
                         type: seqaij
                         rows=330, cols=2000
                         total: nonzeros=22800, allocated nonzeros=22800
used is 5
                     KSP of A00
1 MPI processes
                         type: preonly
divergence=10000
1 MPI processes
                         type: hypre
                         Mat Object:
                           type: seqaij
limit used is 5
                     A01
                         type: seqaij
                         rows=2000, cols=330
used is 5
                   type: seqaij
                   rows=330, cols=330
                     using I-node routines: found 121 nodes, limit used is 5
             maximum iterations=1, initial guess is zero
           PC Object: (fieldsplit_1_mg_levels_0_)           1 MPI processes
             type: sor
processes
               rows=330, cols=330
                 A11
processes
                     type: seqaij
                     rows=330, cols=330
calls =0
used is 5
                 A10
                     type: seqaij
                     rows=330, cols=2000
calls =0
used is 5
                 KSP of A00
processes
                     type: preonly
divergence=10000
processes
                     type: hypre
MPI processes
                       type: seqaij
calls =0
used is 5
                 A01
                     type: seqaij
                     rows=2000, cols=330
calls =0
used is 5
               type: seqaij
               rows=330, cols=330
           rows=330, cols=330
             A11
                 type: seqaij
                 rows=330, cols=330
             A10
                 type: seqaij
                 rows=330, cols=2000
             KSP of A00
                 type: preonly
divergence=10000
                 type: hypre
                   type: seqaij
             A01
                 type: seqaij
                 rows=2000, cols=330
           type: seqaij
           rows=330, cols=330
     type: seqaij
     rows=2330, cols=2330
     total: nonzeros=93242, allocated nonzeros=93242
       using I-node routines: found 521 nodes, limit used is 5
I am not completely surprised by this since the multigrid algorithm
might want to know the structure of my vector in order to do a good job
at restrictions and prolongations, etc... I am just not sure when I
should call: DMShellSetGlobalVector() or DMShellSetCreateGlobalVector().
If I call DMShellSetGlobalVector() I assume that I need to generate my
vector somehow before hand but I don't know what is required to make it
a valid "template" vector?
If I call DMShellSetCreateGlobalVector() I need to pass it a functions
that computes a vector but what kind of vector? A residual or a
"template"? This is not very clear to me...
Best,
Luc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141121/669e3d64/attachment-0001.html>
