[petsc-users] the specific preconditioner
huaibao zhang paulhuaizhang at gmail.com
Fri Nov 21 08:18:58 CST 2014
Hi Jed,
I have a specific question regarding the attached my initialization function.  Previously I used  KSPSetType(ksp,KSPFGMRES) solver, and I would like to see if there is some improvement using the other choices like KSPBCGS. It seems hoverer, the PC         //PCSetType(pc,PCBJACOBI)  does  not work with me. And I am not quite sure why.
By the way, can you please give some suggestions on my code? I am not quite sure if I am doing the things rightly.
Many thanks,
Paul
void petsc_init(void) {
        vector<Cell>::iterator cit;
        vector<int>::iterator it;
        //Create nonlinear solver context
        KSPCreate(PETSC_COMM_WORLD,&ksp);
        VecCreateMPI(PETSC_COMM_WORLD,grid[gid].cellCount*nVars,grid[gid].globalCellCount*nVars,&RHS);
        VecSetFromOptions(RHS);
        VecDuplicate(RHS,&deltaX);
        VecSet(RHS,0.);
        VecSet(deltaX,0.);
        vector<int> diagonal_nonzeros, off_diagonal_nonzeros;
        int nextCellCount;
        // Calculate space necessary for matrix memory allocation
        for (cit=grid[gid].cell.begin();cit!=grid[gid].cell.end();cit++) {
                nextCellCount=0;
                for (it=(*cit).faces.begin();it!=(*cit).faces.end();it++) {
                        if (grid[gid].face[*it].bc==INTERNAL_FACE) {
                                nextCellCount++;
                for (int i=0;i<nVars;++i) {
                        diagonal_nonzeros.push_back( (nextCellCount+1)*nVars);
                        off_diagonal_nonzeros.push_back( ((*cit).ghosts.size())*nVars);
        MatCreateMPIAIJ(
                        PETSC_COMM_WORLD,
                        0,&diagonal_nonzeros[0],
                        0,&off_diagonal_nonzeros[0],
                        &impOP);
        KSPSetOperators(ksp,impOP,impOP,SAME_NONZERO_PATTERN);
        KSPSetTolerances(ksp,rtol,abstol,1.e15,maxits);
        KSPSetType(ksp, KSPBCGS);
        //PCSetType(pc,PCBJACOBI);
        KSPGMRESSetRestart(ksp,30);
        KSPSetFromOptions(ksp);
        return;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141121/41702894/attachment.html>
