[petsc-users] Fortran 77 VecGetArray problems
Valerio Grazioso graziosov at libero.it
Thu Nov 20 21:19:39 CST 2014
Dear Petsc Users,
I’m trying to write a simple parallel linear solver (A*x=q) in fortran 77 with Petsc.
I managed to Setup a MPIAIJ matrix A  and a VecMPI qvec
then the KSP and the solution.
Everything seems fine (I’ve checked both A and q with MatView and VecView) but I’m having problems getting the solution in a “normal” local double precision fortran vector.
To be more than sure I’ve tried to repeat the necessary steps in order to achieve this result on qvec :
After creating and calling a VecScatter in order to bring a sequential version on all the processors (as described in
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#mpi-vec-to-mpi-vec)
I’ve tried to use VecGetValue as described in the User manual in the Fortran users chapter (pag. 147-148)
It seems to fail in both the local xx_v vector (that has wrong values) and in calculating the i_x index offset that has a very large negative value
that, when it is used, generates an obvious “Aut of bound” error.
I’ve tried to use VecGetValue also on qvec directly : same result!
There must be something wrong that I’m doing.
Can anybody point me in the right direction?
Thanks
Regards
Valerio Grazioso
Here it is the relevant code:
#define xx_a(ib)  xx_v(i_x + (ib))
      Vec         xSEQ
      PetscScalar xx_v(1)
      PetscOffset i_x
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecCreate"
      call VecCreate(comm,qvec,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecSetSizes"
      call VecSetSizes(qvec,PETSC_DECIDE,NCELL,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecSetFromOptions"
      call VecSetFromOptions(qvec,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecDuplicate"
      call VecDuplicate(qvec,xvec,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecGetOwnershipRange"
      call VecGetOwnershipRange(qvec,Istart,Iend,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a,2i8)'),"Processor  ",mpi_rank,": petsc_solve ---> Istart,Iend (Vet)=", Istart,Iend
      do Iproc = 0,(mpi_size-1)
        if (Iproc == mpi_rank) then
          do I= (Istart+1), (Iend)
C            write(6,'(a,i2,a,2i8)'),"Processor  ",mpi_rank,": petsc_solve ---> MatSetValues",I,I
            call VecSetValues(qvec,1,I-1,SU(I),INSERT_VALUES,ierr); CHKERRQ(ierr)
            call VecSetValues(xvec,1,I-1,0.E0,INSERT_VALUES,ierr); CHKERRQ(ierr)
          enddo
        endif
      enddo
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecAssemblyBegin"
      call VecAssemblyBegin(qvec,ierr); CHKERRQ(ierr)
      call VecAssemblyEnd(qvec,ierr); CHKERRQ(ierr)
      call VecAssemblyBegin(xvec,ierr); CHKERRQ(ierr)
      call VecAssemblyEnd(xvec,ierr); CHKERRQ(ierr)
      write(6,'(a,i2,a)'),"Processor  ",mpi_rank,": petsc_solve ---> VecAssemblyEnd"
C ---------------------------------  DEBUG -------------------------------------
      if (1 == 1) then
         call VecScatterCreateToAll(qvec,ctx,xSEQ,ierr); CHKERRQ(ierr)
         call VecScatterBegin(ctx,qvec,xSEQ,INSERT_VALUES,SCATTER_FORWARD,ierr)
         CHKERRQ(ierr)
         call VecScatterEnd(ctx,qvec,xSEQ,INSERT_VALUES,SCATTER_FORWARD,ierr)
         CHKERRQ(ierr)
         call VecScatterDestroy(ctx,ierr); CHKERRQ(ierr)
C         call PetscViewerCreate(comm, view, ierr); CHKERRQ(ierr)
C         call PetscViewerSetType(view, PETSCVIEWERASCII, ierr); CHKERRQ(ierr)
C         call PetscViewerSetFormat(view, PETSC_VIEWER_ASCII_INDEX, ierr)
C         CHKERRQ(ierr)
C         call PetscViewerFileSetName(view, 'qvec.m', ierr)
C         call VecView(xSEQ, view, ierr); CHKERRQ(ierr)
C         call PetscViewerDestroy(view, ierr); CHKERRQ(ierr)
         call VecGetArray(xSEQ,xx_v,i_x,ierr); CHKERRQ(ierr)
            write(6, *) (xx_a(I), I=1,NCELL)
            write(6,'(a,i20)')"i_x = ", i_x
         call VecRestoreArray(xSEQ,xx_v,i_x,ierr); CHKERRQ(ierr)
         call PetscFinalize(ierr); CHKERRQ(ierr)
         STOP
      endif
C ---------------------------------- END DEBUG ------------------------------
