[petsc-users] MPI+OpenMP in PETSC
Evan Um evanum at gmail.com
Wed Nov 19 11:43:55 CST 2014
Dear PETSC users,
I would like to ask a question about using an external library with
MPI+OpenMP in PETSC. For example, within PETSC, I want to use MUMPS with
MPI+OpenMP. This means that if one node has 12 MPI processes and 24GB,
MUMPS uses 4 MPI processes with 6GB and each MPI process has 3 threads. To
do this, what should be done from PETSC installation? After using MUMPS in
this way, is there a way to convert from MPI+OpenMP to flat MPI? Thank you!
Evan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141119/ddaa1e6b/attachment.html>
