[petsc-users] PetscQuadratureCreate and PETSC_OBJECT_CLASSID
Tue Nov 18 16:54:44 CST 2014
On Tue, Nov 18, 2014 at 4:09 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Okay - maybe you meant PetscSysInitializePackage() needs to get first?
Yes I meant that. Something has to register our classes. I can put this
call into the DT functions.
  Matt
> In this simple test I was running, I essentially called
> PetscInitialize
> PetscDTGaussTensorQuadrature
> PetscFinalize
> and thus no one call PetscSysInitializePackage() before
> PetscDTGaussTensorQuadrature().
> Thanks - my test works now.
> Cheers,
>   Dave
> On 18 November 2014 22:51, Dave May <dave.mayhem23 at gmail.com> wrote:
>> Okay, thanks Matt. It now makes sense why it failed, but I don't
>> understand your logic.
>> The PetscQuadrature class is so small and doesn't depend on DM (at least
>> not in the definition of the structure described PetscQuadrature). Hence,
>> why should DMInitializePackage() have to be called at all?
>> I realize you how are you using PetscDT, but it should be available for
>> everyone - even if they don't ever create a DM.
>> Cheers,
>>   Dave
>> On 18 November 2014 22:46, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Nov 18, 2014 at 1:49 PM, Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I was trying to use some of DT functionality (in particular
>>>> PetscDTGaussTensorQuadrature()) in petsc 3.5.2 and I encountered this error:
>>> I did not anticipate someone calling that before anything by itself. You
>>> need a call to
>>> This is called by PetscQuadratureCreate().
>>>    Matt
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Invalid argument
>>>> [0]PETSC ERROR: Invalid object classid 0
>>>> This could happen if you compile with PETSC_HAVE_DYNAMIC_LIBRARIES, but
>>>> link with static libraries.
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>>>> [0]PETSC ERROR: ./dmdadg.app on a arch-darwin-c-mpi-debug-f2c named
>>>> nikkan.local by dmay Tue Nov 18 20:34:56 2014
>>>> [0]PETSC ERROR: Configure options --download-openmpi=yes
>>>> --with-debugging=yes --with-fc=0 --download-f2cblaslapck=yes
>>>> PETSC_ARCH=arch-darwin-c-mpi-debug-f2c
>>>> [0]PETSC ERROR: #1 PetscClassRegLogGetClass() line 290 in
>>>> /Users/dmay/software/petsc-3.5.2/src/sys/logging/utils/classlog.c
>>>> [0]PETSC ERROR: #2 PetscLogObjCreateDefault() line 317 in
>>>> [0]PETSC ERROR: #3 PetscQuadratureCreate() line 35 in
>>>> /Users/dmay/software/petsc-3.5.2/src/dm/dt/interface/dt.c
>>>> [0]PETSC ERROR: #4 PetscDTGaussTensorQuadrature() line 322 in
>>>> [0]PETSC ERROR: #5 DMDGSpace_ex4_quadrature() line 480 in dmdadg.c
>>>> [0]PETSC ERROR: #6 main() line 503 in dmdadg.c
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>> with errorcode 1.
>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> You may or may not see output from other processes, depending on
>>>> exactly when Open MPI kills them.
>>>> Snooping around in the source tree, the only place where I can find
>>>> PetscHeaderCreate being passed PETSC_OBJECT_CLASSID is within
>>>> src/dm/dt/interface/dt.c in the function PetscQuadratureCreate().
>>>> Is this is a bug or is my petsc build broken??
>>>> I'm sure I am linking against a dynamic library (or whatever you want
>>>> to call a dylib on OSX)
>>>> dmay at nikkan:~/codes/dgspace$ otool -L dmdadg.app
>>>> dmdadg.app:
>>>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libpetsc.3.5.dylib
>>>> (compatibility version 3.5.0, current version 3.5.2)*
>>>> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
>>>> (compatibility version 1.0.0, current version 1.0.0)
>>>> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
>>>>     /opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current
>>>> version 10.0.0)
>>>>     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
>>>> version 1197.1.1)
>>>>     /usr/lib/libssl.0.9.8.dylib (compatibility version 0.9.8, current
>>>> version 50.0.0)
>>>>     /usr/lib/libcrypto.0.9.8.dylib (compatibility version 0.9.8,
>>>> current version 50.0.0)
>>>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi_cxx.1.dylib
>>>> (compatibility version 3.0.0, current version 3.3.0)
>>>>     /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current
>>>> version 120.0.0)
>>>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi.1.dylib
>>>> (compatibility version 7.0.0, current version 7.0.0)
>>>> Cheers,
>>>>   Dave
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141118/3427d529/attachment-0001.html>
