[petsc-users] Roles of ksp_type and pc_type
Thu Nov 13 06:39:38 CST 2014
On Thu, Nov 13, 2014 at 6:24 AM, Massimiliano Leoni <
leoni.massimiliano1 at gmail.com> wrote:
> In data giovedì 13 novembre 2014 05:59:17, hai scritto:
> > On Thu, Nov 13, 2014 at 5:39 AM, Massimiliano Leoni <
> > We call Hypre directly to apply P^{-1}.
> > It should be. Send -ksp_view and we can verify.
> It looks like that's what's happening! :D
> Here it is
> http://pastebin.com/6J3Rj4x1
This is not exactly right because here you are just using additive
fieldsplit. The mass matrix
is a good preconditioner for the Schur complement, not the zero matrix.
Take a look at these
slides:
  http://www.mcs.anl.gov/petsc/documentation/tutorials/ParisTutorial.pdf
at slide 115, or my talk from SIAM CS&E
  http://people.cs.uchicago.edu/~knepley/presentations/SIAMCSE13.pdf
    Matt
> > You should use
> >   -pc_fieldsplit_schur_factorization_type diag
> Ok, This is not clear to me.
> According to what I studied, Schur decomposition is when I formally
> eliminate
> a variable [for Stokes, velocity u] and get a system in the others [sole
> pressure], which I then solve by some smart method and substitute back to
> find
> u. This is done on the full Stokes matrix A, not on the preconditioner...
> It should be not what I want to do, as I'm facing the whole system at once.
> What does PETSc mean by "Schur" here?
> >    Thanks,
> >       Matt
> Thank you very much!
> Massimiliano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141113/837bdc46/attachment-0001.html>
