[petsc-users] Roles of ksp_type and pc_type
Massimiliano Leoni leoni.massimiliano1 at gmail.com
Thu Nov 13 06:24:30 CST 2014
In data giovedì 13 novembre 2014 05:59:17, hai scritto:
> On Thu, Nov 13, 2014 at 5:39 AM, Massimiliano Leoni <
> We call Hypre directly to apply P^{-1}.
> It should be. Send -ksp_view and we can verify.
It looks like that's what's happening! :D
Here it is
http://pastebin.com/6J3Rj4x1
> You should use
>   -pc_fieldsplit_schur_factorization_type diag
Ok, This is not clear to me.
According to what I studied, Schur decomposition is when I formally eliminate
a variable [for Stokes, velocity u] and get a system in the others [sole
pressure], which I then solve by some smart method and substitute back to find
u. This is done on the full Stokes matrix A, not on the preconditioner...
It should be not what I want to do, as I'm facing the whole system at once.
What does PETSc mean by "Schur" here?
>    Thanks,
>       Matt
Thank you very much!
Massimiliano
