[petsc-users] Reading data from a file into a DM created vector
Justin Chang jychang48 at gmail.com
Sun Nov 2 00:24:47 CDT 2014
Nevermind, I just looked at some of the DM test examples and it answered my
question. Thanks
On Sat, Nov 1, 2014 at 7:22 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Matt, Okay that makes a lot of sense now, thank you so much. Sorry I have
> one more question then I will leave you all alone :)
> From what I understand about creating DMPlex, it seems that if there are
> multiple processes, only the root rank populates the DM structure. I see
> that DMPlexCreateBoxMesh as well as the GMSH/Exodus/CGNS readers have rank
> 0 read the mesh files and populate the sieve/mesh points within the DMPlex
> (assuming that the DM was created with PETSC_COMM_WORLD).
> However, when I look at the DMPlexCreateFromDAG and
> DMPlexCreateFromCellList functions, I don't see anywhere where only rank 0
> handles the creation of the DM structure. I do notice that
> DMPlexCreateFromDAG already requires the DM structure to be created. So I
> guess my question is, is it possible to simply have rank 0 invoke the
> DMPlexCreateFromDAG function? Because that way only the root process reads
> the mesh data file and creates/distributes the DMPlex among the remaining
> processors.
> Thanks,
> Justin
> On Sat, Nov 1, 2014 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Nov 1, 2014 at 12:20 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Thanks for the response. On a related note,
>>> In the source code of SNES ex12, where is the PetscSection actually
>>> being created? I can't seem to find anywhere in the code or its routines
>>> where the creation has been explicitly called. Because when the
>>> discretization/problem is define, I imagine a PetscSection for the fields
>>> and constraints has to be invoked somewhere. It seems to me as soon as
>>> DMPlexAddBoundary() is called it creates the PetscSectionConstraints but I
>>> can't seem to really confirm this within the source of that function. The
>>> reason I want to know this is because if I really were to declare my own
>>> constraints, I want to make sure that the PetscSection for the field
>>> variables has already been set up.
>> Much of the mechanism has been moved into the library. The reason I did
>> this was to make things like
>> nonlinear multigrid automatic, rather than making the user define a
>> different section on each level. Let
>> me explain what is happening. When we call DMGetDefaultSection(), if the
>> section is not present it
>> will call the createdefaultsection() member function:
>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/interface/dm.c?at=master#cl-2977
>> which for Plex is here
>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-5601
>> It uses the discretization information from PetscDS and the BC
>> information from DMPlexAddBoundary() to build the inputs for
>> DMPlexCreateSection()
>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-5739
>> I realize that call is still limited. For example, it constrains all dofs
>> on a point, but sometimes you only want to constrain some. In
>> the most general case, you would just build the Section manually, using
>> the same tools I use in DMPlexCreateSection():
>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-3204
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>>> Sent from my iPhone
>>> On Nov 1, 2014, at 11:40 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Oct 31, 2014 at 4:15 PM, Justin Chang <jychang48 at gmail.com>
>>> wrote:
>>>> Matt,
>>>> Thanks for the response. One more question:
>>>> If I go with approach 2, will manually setting the constraints/indices
>>>> and its values be compatible with the DMPlexSNESComputeResidual/JacobianFEM
>>>> routines? When I look at the source code of those routines it seems the
>>>> constrained values are added to the local solution vectors via
>>>> DMPlexInsertBoundaryValuesFEM. If I choose not to use DMPlexAddBoundary and
>>>> wish to manually declare my boundary values, i assume I should call
>>>> DMPlexProjectField with mode INSERT_BC_VALUES?
>>> Yes, exactly. I use DMPlexProjectFunctionLabelLocal(),
>>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plexfem.c?at=master#cl-576
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Justin
>>>> Sent from my iPhone
>>>> On Oct 30, 2014, at 4:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Oct 30, 2014 at 4:16 PM, Justin Chang <jychang48 at gmail.com>
>>>> wrote:
>>>>> Matt, thanks for the quick response.
>>>>> What about for (dirichlet) boundary conditions? Would it be possible
>>>>> to do something similar for those, like using those
>>>>> PetscSectionSetConstraint functions?
>>>> Yes. There are generally two ways of handling Dirichlet conditions:
>>>>   1) Replace those rows of the Jacobian with the identity and put the
>>>> boundary value in the rhs. I find
>>>>       this cumbersome for nonlinear solves.
>>>>   2) Remove these unknowns from the system using
>>>> PetscSectionSetConstraintDof() and ConstratinIndices().
>>>> The DMPlexAddBoundary() functions are automating this processing by
>>>> marking boundaries using DMLabels,
>>>> and then constraining dofs on those boundaries.
>>>>   Thanks,
>>>>     Matt
>>>>> Thanks,
>>>>> Justin
>>>>> On Thu, Oct 30, 2014 at 3:35 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Oct 30, 2014 at 3:29 PM, Justin Chang <jychang48 at gmail.com>
>>>>>> wrote:
>>>>>>> Hi all,
>>>>>>> So I am writing an FEM code where it reads input data (e.g.,
>>>>>>> auxiliary coefficients, source terms, etc) from a text file. I have
>>>>>>> preprocessed the data text file so that each vertex point has its
>>>>>>> corresponding data. For instance, if my source term for a diffusion problem
>>>>>>> has a sin or cos function of the coordinates, then this data is already
>>>>>>> tabulated and simply needs to be fed into my PETSc program. The data text
>>>>>>> file containing both the auxiliary data and the coordinate/connectivities
>>>>>>> will also be used to provide the input arguments for the
>>>>>>> DMPlexCreateFromDAG() function.
>>>>>>> Normally, I would hard-code the sin/cos functions into the source
>>>>>>> code itself, but i want my program to be "universal" in that it can take as
>>>>>>> input any user-defined function for not only these auxiliaries but for
>>>>>>> other things like boundary conditions. I see that PETSc has a lot of
>>>>>>> examples on how to read data into vectors and matrices, but I guess my
>>>>>>> question is is there a way to project data from a text file into a vector
>>>>>>> that has already been created with a defined DM structure?
>>>>>> If you have the functions available, I think it is far more universal
>>>>>> to use the function itself, since then you can be independent
>>>>>> of mesh and discretization when specifying input and BC.
>>>>>> However, if you want to read it in, and you guarantee that it matches
>>>>>> the mesh and discretization, I think the easiest thing to do is
>>>>>> demand that it come in the same order as the vertices and use
>>>>>> VecGetArray(V, &a);
>>>>>> for (v = vStart, i = 0; v < vEnd; ++v) {
>>>>>>   PetscSectionGetDof(s, v, &dof);
>>>>>>   PetscSectionGetOffset(s, v, &off);
>>>>>>   for (d = 0; d < dof; ++d) a[off+d] = text_data[i++];
>>>>>> VecRestoreArray(V, &a);
>>>>>>    Matt
>>>>>>> Thanks,
>>>>>>> Justin
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141102/5bcbf2f2/attachment-0001.html>
