[petsc-users] Reading data from a file into a DM created vector
Justin Chang jychang48 at gmail.com
Sat Nov 1 19:22:50 CDT 2014
Matt, Okay that makes a lot of sense now, thank you so much. Sorry I have
one more question then I will leave you all alone :)
>From what I understand about creating DMPlex, it seems that if there are
multiple processes, only the root rank populates the DM structure. I see
that DMPlexCreateBoxMesh as well as the GMSH/Exodus/CGNS readers have rank
0 read the mesh files and populate the sieve/mesh points within the DMPlex
(assuming that the DM was created with PETSC_COMM_WORLD).
However, when I look at the DMPlexCreateFromDAG and
DMPlexCreateFromCellList functions, I don't see anywhere where only rank 0
handles the creation of the DM structure. I do notice that
DMPlexCreateFromDAG already requires the DM structure to be created. So I
guess my question is, is it possible to simply have rank 0 invoke the
DMPlexCreateFromDAG function? Because that way only the root process reads
the mesh data file and creates/distributes the DMPlex among the remaining
processors.
Justin
On Sat, Nov 1, 2014 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Nov 1, 2014 at 12:20 PM, Justin Chang <jychang48 at gmail.com> wrote:
>> Thanks for the response. On a related note,
>> In the source code of SNES ex12, where is the PetscSection actually being
>> created? I can't seem to find anywhere in the code or its routines where
>> the creation has been explicitly called. Because when the
>> discretization/problem is define, I imagine a PetscSection for the fields
>> and constraints has to be invoked somewhere. It seems to me as soon as
>> DMPlexAddBoundary() is called it creates the PetscSectionConstraints but I
>> can't seem to really confirm this within the source of that function. The
>> reason I want to know this is because if I really were to declare my own
>> constraints, I want to make sure that the PetscSection for the field
>> variables has already been set up.
> Much of the mechanism has been moved into the library. The reason I did
> this was to make things like
> nonlinear multigrid automatic, rather than making the user define a
> different section on each level. Let
> me explain what is happening. When we call DMGetDefaultSection(), if the
> section is not present it
> will call the createdefaultsection() member function:
> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/interface/dm.c?at=master#cl-2977
> which for Plex is here
> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-5601
> It uses the discretization information from PetscDS and the BC information
> from DMPlexAddBoundary() to build the inputs for
> DMPlexCreateSection()
> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-5739
> I realize that call is still limited. For example, it constrains all dofs
> on a point, but sometimes you only want to constrain some. In
> the most general case, you would just build the Section manually, using
> the same tools I use in DMPlexCreateSection():
> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plex.c?at=master#cl-3204
>   Thanks,
>      Matt
>> Thanks,
>> Justin
>> Sent from my iPhone
>> On Nov 1, 2014, at 11:40 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Oct 31, 2014 at 4:15 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Matt,
>>> Thanks for the response. One more question:
>>> If I go with approach 2, will manually setting the constraints/indices
>>> and its values be compatible with the DMPlexSNESComputeResidual/JacobianFEM
>>> routines? When I look at the source code of those routines it seems the
>>> constrained values are added to the local solution vectors via
>>> DMPlexInsertBoundaryValuesFEM. If I choose not to use DMPlexAddBoundary and
>>> wish to manually declare my boundary values, i assume I should call
>>> DMPlexProjectField with mode INSERT_BC_VALUES?
>> Yes, exactly. I use DMPlexProjectFunctionLabelLocal(),
>> https://bitbucket.org/petsc/petsc/src/ea1a9a653238fa98fb68e87b49145608ab6e5301/src/dm/impls/plex/plexfem.c?at=master#cl-576
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>>> Sent from my iPhone
>>> On Oct 30, 2014, at 4:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Oct 30, 2014 at 4:16 PM, Justin Chang <jychang48 at gmail.com>
>>> wrote:
>>>> Matt, thanks for the quick response.
>>>> What about for (dirichlet) boundary conditions? Would it be possible to
>>>> do something similar for those, like using those PetscSectionSetConstraint
>>>> functions?
>>> Yes. There are generally two ways of handling Dirichlet conditions:
>>>   1) Replace those rows of the Jacobian with the identity and put the
>>> boundary value in the rhs. I find
>>>       this cumbersome for nonlinear solves.
>>>   2) Remove these unknowns from the system using
>>> PetscSectionSetConstraintDof() and ConstratinIndices().
>>> The DMPlexAddBoundary() functions are automating this processing by
>>> marking boundaries using DMLabels,
>>> and then constraining dofs on those boundaries.
>>>   Thanks,
>>>     Matt
>>>> Thanks,
>>>> Justin
>>>> On Thu, Oct 30, 2014 at 3:35 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Oct 30, 2014 at 3:29 PM, Justin Chang <jychang48 at gmail.com>
>>>>> wrote:
>>>>>> Hi all,
>>>>>> So I am writing an FEM code where it reads input data (e.g.,
>>>>>> auxiliary coefficients, source terms, etc) from a text file. I have
>>>>>> preprocessed the data text file so that each vertex point has its
>>>>>> corresponding data. For instance, if my source term for a diffusion problem
>>>>>> has a sin or cos function of the coordinates, then this data is already
>>>>>> tabulated and simply needs to be fed into my PETSc program. The data text
>>>>>> file containing both the auxiliary data and the coordinate/connectivities
>>>>>> will also be used to provide the input arguments for the
>>>>>> DMPlexCreateFromDAG() function.
>>>>>> Normally, I would hard-code the sin/cos functions into the source
>>>>>> code itself, but i want my program to be "universal" in that it can take as
>>>>>> input any user-defined function for not only these auxiliaries but for
>>>>>> other things like boundary conditions. I see that PETSc has a lot of
>>>>>> examples on how to read data into vectors and matrices, but I guess my
>>>>>> question is is there a way to project data from a text file into a vector
>>>>>> that has already been created with a defined DM structure?
>>>>> If you have the functions available, I think it is far more universal
>>>>> to use the function itself, since then you can be independent
>>>>> of mesh and discretization when specifying input and BC.
>>>>> However, if you want to read it in, and you guarantee that it matches
>>>>> the mesh and discretization, I think the easiest thing to do is
>>>>> demand that it come in the same order as the vertices and use
>>>>> VecGetArray(V, &a);
>>>>> for (v = vStart, i = 0; v < vEnd; ++v) {
>>>>>   PetscSectionGetDof(s, v, &dof);
>>>>>   PetscSectionGetOffset(s, v, &off);
>>>>>   for (d = 0; d < dof; ++d) a[off+d] = text_data[i++];
>>>>> VecRestoreArray(V, &a);
>>>>>    Matt
>>>>>> Thanks,
>>>>>> Justin
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141101/f1cf1d21/attachment.html>
