[petsc-users] Question on DMMGSetSNESLocal from snes/example/tutorials/ex19.c
Jed Brown jed at jedbrown.org
Sat May 31 18:13:34 CDT 2014
"Sun, Hui" <hus003 at ucsd.edu> writes:
> Thanks Jed. It converges now. With a 32 by 32 grid, it takes 3.1076 seconds on 8 cores and 7.13586 seconds on 2 cores. With a 64 by 64 grid, it takes 18.1767s and 55.0017s respectively. That seems quite reasonable.
> By the way, how do I know which matrix solver and which preconditioner is being called?
-ksp_view (or -snes_view, which includes the same information once per nonlinear solve).
> Besides, I have another question: I try to program finite difference
> for 2D Stokes flow with Dirichlet or Neumann bdry conditions, using
> staggered MAC grid. I looked up all the examples in snes, there are
> three stokes flow examples, all of which are finite element. I was
> thinking about naming (i-1/2,j), (i,j-1/2) and (i,j) all as (i,j),
> then define u, v, p as three petscscalers on (i,j), but in that case u
> will have one more column than p and v will have one more row than
> p. If there is already something there in PETSc about MAC grid, then I
> don't have to worry about those details. Do you know any examples or
> references doing that?
What you describe is a common approach.  You set trivial "boundary
conditions" for those silent dofs and otherwise ignore them.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140601/d1fdf413/attachment.pgp>
