[petsc-users] Question on DMMGSetSNESLocal from snes/example/tutorials/ex19.c
Sun, Hui hus003 at ucsd.edu
Sat May 31 18:06:37 CDT 2014
Thanks Jed. It converges now. With a 32 by 32 grid, it takes 3.1076 seconds on 8 cores and 7.13586 seconds on 2 cores. With a 64 by 64 grid, it takes 18.1767s and 55.0017s respectively. That seems quite reasonable.
By the way, how do I know which matrix solver and which preconditioner is being called?
Besides, I have another question: I try to program finite difference for 2D Stokes flow with Dirichlet or Neumann bdry conditions, using staggered MAC grid. I looked up all the examples in snes, there are three stokes flow examples, all of which are finite element. I was thinking about naming (i-1/2,j), (i,j-1/2) and (i,j) all as (i,j), then define u, v, p as three petscscalers on (i,j), but in that case u will have one more column than p and v will have one more row than p. If there is already something there in PETSc about MAC grid, then I don't have to worry about those details. Do you know any examples or references doing that?
Hui
Sent: Saturday, May 31, 2014 2:48 PM
To: Sun, Hui; petsc-users at mcs.anl.gov
Subject: RE: [petsc-users] Question on DMMGSetSNESLocal from snes/example/tutorials/ex19.c
"Sun, Hui" <hus003 at ucsd.edu> writes:
> Thank you Jed for explaining this to me. I tried to compile and run with the following options:
> ./ex19 -lidvelocity 100 -grashof 1e4 -da_grid_x 32 -da_grid_y 32 -da_refine 2 -snes_monitor_short -snes_converged_reason
> 1). I use 2 cores and get the following output:
> lid velocity = 100, prandtl # = 1, grashof # = 10000
>   0 SNES Function norm 1111.93
>   1 SNES Function norm 829.129
>   2 SNES Function norm 532.66
>   3 SNES Function norm 302.926
>   4 SNES Function norm 3.64014
>   5 SNES Function norm 0.0410053
>   6 SNES Function norm 4.57951e-06
> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 6
> Number of SNES iterations = 6
> Time cost for creating solver context 0.000907183 s, and for solve 25.2764 s.
> 2). I use 8 cores and get the following output:
>   1 SNES Function norm 829.049
>   2 SNES Function norm 532.616
>   3 SNES Function norm 303.165
>   4 SNES Function norm 3.93436
> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 4
> Number of SNES iterations = 4
> Time cost for creating solver context 0.0244079 s, and for solve 25.0607 s.
> First of all, the two runs yields different results.
The linear solve did not converge in the second case.
Run a more robust linear solver.  These problems can get difficult, but
I think -pc_type asm -sub_pc_type lu should be sufficient.
> Secondly, the time cost comparison doesn't seem to be scaling correctly.
> ( I have used petsctime.h to calculate the time cost. )
1. Run in optimized mode.
2. Don't use more processes than you have cores (I don't know if this
affects you).
3. This problem is too small to take advantage of much (if any)
parallelism.
