[petsc-users] Question on local vec to global vec for dof > 1
Danyang Su danyang.su at gmail.com
Thu May 22 18:33:01 CDT 2014
Hi Barry,
I use the following routine to reorder from the local rhs to global rhs.
               PetscScalar, pointer :: vecpointer1d(:,:)
               call DMDAVecGetArrayF90(da,x_vec_gbl,vecpointer1d,ierr)
     !x_vec_gbl is a global vector created by DMCreateGlobalVector
               do i = nvzls,nvzle !local node number without ghost node
                 vecpointer1d(0,i-1) = x_array_loc(i-nvzgls+1)
!x_array_loc is local rhs
                 vecpointer1d(1,i-1) = x_array_loc(i-nvzgls+1+nvz) !nvz
= 6 for the present 1d example
               end do
               call DMDAVecRestoreArrayF90(da,x_vec_gbl,vecpointer1d,ierr)
Now Vecview gives the same rhs for 1 processor and 2 processors, but rhs
order is not what I expected. I want global rhs vector hold the values
of dof=1 first and then dof=2 as the local matrix and rhs hold value in
this order.
x_vec_gbl x_vec_gbl
dof       node VecView(Current)   dof      node VecView (Expected)
1          1          1.39598e-021             1 1          1.39598e-021
2          1          0 1         2          0
1          2          -0 1         3          0
2          2          -0 1         4          5.64237e-037
1          3          -0 1         5          0
2          3          -0 1         6          -7.52316e-037
1          4          5.64237e-037             1 7          7.52316e-037
2          4          4.81482e-035             1 8          0
1          5          -0 1         9          1.68459e-016
2          5          -0 1         10         0.1296
1          6          -7.52316e-037            2 1          0
2          6          -7.22224e-035            2 2          0
1          7          7.52316e-037             2 3          0
2          7          7.22224e-035             2 4          4.81482e-035
1          8          -0 2         5          0
2          8          -0 2         6          -7.22224e-035
1          9          1.68459e-016             2 7          7.22224e-035
2          9          128623                        2 8          0
1          10         0.1296                        2 9          128623
2          10         0                                  2 10         0
Thanks and regards,
Danyang
On 22/05/2014 4:03 PM, Barry Smith wrote:
>    Always do things one small step at at time. On one process what is x_vec_loc (use VecView again on it). Is it what you expect? Then run on two processes but call VecView on
> x_vec_loc only on the first process. Is it what you expect?
>    Also what is vecpointer1d declared to be?
>    Barry
> On May 22, 2014, at 4:44 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> On 22/05/2014 12:01 PM, Matthew Knepley wrote:
>>> On Thu, May 22, 2014 at 1:58 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> Hi All,
>>> I have a 1D transient flow problem (1 dof) coupled with energy balance (1 dof), so the total dof per node is 2.
>>> The whole domain has 10 nodes in z direction.
>>> The program runs well with 1 processor but failed in 2 processors. The matrix is the same for 1 processor and 2 processor but the rhs are different.
>>> The following is used to set the rhs value.
>>> call VecGetArrayF90(x_vec_loc, vecpointer, ierr)
>>> vecpointer = (calculate the rhs value here)
>>> call VecRestoreArrayF90(x_vec_loc,vecpointer,ierr)
>>> call DMLocalToGlobalBegin(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
>>> call DMLocalToGlobalEnd(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
>>>        Vecview  Correct             Vecview  Wrong
>>> dof     local node           Process [0]                                  Process [0]                      Process [0]
>>> 1            1              1.395982780116148E-021               1.39598e-021                 1.39598e-021
>>> 1            2              0.000000000000000E+000               0                                       0
>>> 1            3              0.000000000000000E+000               0                                       0
>>> 1            4              5.642372883946980E-037               5.64237e-037                 5.64237e-037
>>> 1            5              0.000000000000000E+000                0                                       0
>>> 1            6             -1.395982780116148E-021               -7.52316e-037                -1.39598e-021                       Line A
>>> 2            1              0.000000000000000E+000               7.52316e-037                 0
>>> 2            2              0.000000000000000E+000                0                                       0
>>> 2            3              0.000000000000000E+000               1.68459e-016                  0
>>> 2            4              4.814824860968090E-035                0.1296                             4.81482e-035
>>> 2            5              0.000000000000000E+000                                                        Process [1]                             Line B
>>> 2            6             -1.371273884908092E-019               0                                        7.52316e-037                       Line C
>>>        0                                        0
>>>                                         Process [1]                                   0                                       1.68459e-016
>>> 1            1              1.395982780116148E-021               4.81482e-035                 0.1296                                     Line D
>>> 1            2             -7.523163845262640E-037                0                                      1.37127e-019                         Line E
>>> 1            3              7.523163845262640E-037               -7.22224e-035                -7.22224e-035
>>> 1            4              0.000000000000000E+000               7.22224e-035                 7.22224e-035
>>> 1            5              1.684590875336239E-016                0                                       0
>>> 1            6              0.129600000000000                         128623                            128623
>>> 2            1              1.371273884908092E-019               0                                       0                                                Line F
>>> 2            2             -7.222237291452134E-035
>>> 2            3              7.222237291452134E-035
>>> 2            4              0.000000000000000E+000
>>> 2            5               128623.169844761
>>> 2            6              0.000000000000000E+000
>>> The red line (Line A, C, D and F) is the ghost values for 2 subdomains, but when run with 2 processor, the program treates Line B, C, D, and E as ghost values.
>>> How can I handle this kind of local vector to global vector assembly?
>>> Why are you not using DMDAVecGetArrayF90()? This is exactly what it is for.
>> Thanks, Matthew.
>> I tried the following codes but still cannot get the correct global rhs vector
>> call DMDAVecGetArrayF90(da,x_vec_loc,vecpointer1d,ierr)
>> do i = 1,nvz        !nvz is local node amount, here is 6
>>    vecpointer1d(0,i-1) = x_array_loc(i)                              !assume x_array_loc is the local rhs (the third column in the above mentioned data)
>>    vecpointer1d(1,i-1) = x_array_loc(i+nvz)
>> end do
>> call DMDAVecRestoreArrayF90(da,x_vec_loc,vecpointer1d,ierr)
>> Now the rhs for 1 processor is as follows. It is not what I want.
>> 1.39598e-021
>> 0
>> -0
>> -0
>> -0
>> -0
>> 5.64237e-037
>> 4.81482e-035
>> -0
>> -0
>> -7.52316e-037
>> -7.22224e-035
>> 7.52316e-037
>> 7.22224e-035
>> -0
>> -0
>> 1.68459e-016
>> 128623
>> 0.1296
>> 0
>>>     Matt
>>> In fact, the codes can work if the dof and local node is as follows.
>>> dof     local node
>>> 1            1
>>> 2            1
>>> 1            2
>>> 2            2
>>> 1            3
>>> 2            3
>>> Thanks and regards,
>>> Danyang
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140522/c0054988/attachment-0001.html>
