[petsc-users] Question on local vec to global vec for dof > 1
Thu May 22 18:03:01 CDT 2014
  Always do things one small step at at time. On one process what is x_vec_loc (use VecView again on it). Is it what you expect? Then run on two processes but call VecView on
x_vec_loc only on the first process. Is it what you expect?
  Also what is vecpointer1d declared to be?
  Barry
On May 22, 2014, at 4:44 PM, Danyang Su <danyang.su at gmail.com> wrote:
> On 22/05/2014 12:01 PM, Matthew Knepley wrote:
>> On Thu, May 22, 2014 at 1:58 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi All,
>> I have a 1D transient flow problem (1 dof) coupled with energy balance (1 dof), so the total dof per node is 2.
>> The whole domain has 10 nodes in z direction.
>> The program runs well with 1 processor but failed in 2 processors. The matrix is the same for 1 processor and 2 processor but the rhs are different.
>> The following is used to set the rhs value.
>> call VecGetArrayF90(x_vec_loc, vecpointer, ierr)
>> vecpointer = (calculate the rhs value here)
>> call VecRestoreArrayF90(x_vec_loc,vecpointer,ierr)
>> call DMLocalToGlobalBegin(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
>> call DMLocalToGlobalEnd(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
>>        Vecview  Correct             Vecview  Wrong
>> dof     local node           Process [0]                                  Process [0]                      Process [0]
>> 1            1              1.395982780116148E-021               1.39598e-021                 1.39598e-021
>> 1            2              0.000000000000000E+000               0                                       0
>> 1            3              0.000000000000000E+000               0                                       0
>> 1            4              5.642372883946980E-037               5.64237e-037                 5.64237e-037
>> 1            5              0.000000000000000E+000                0                                       0
>> 1            6             -1.395982780116148E-021               -7.52316e-037                -1.39598e-021                       Line A
>> 2            1              0.000000000000000E+000               7.52316e-037                 0
>> 2            2              0.000000000000000E+000                0                                       0
>> 2            3              0.000000000000000E+000               1.68459e-016                  0
>> 2            4              4.814824860968090E-035                0.1296                             4.81482e-035
>> 2            5              0.000000000000000E+000                                                        Process [1]                             Line B
>> 2            6             -1.371273884908092E-019               0                                        7.52316e-037                       Line C
>>        0                                        0
>>                                        Process [1]                                   0                                       1.68459e-016
>> 1            1              1.395982780116148E-021               4.81482e-035                 0.1296                                     Line D
>> 1            2             -7.523163845262640E-037                0                                      1.37127e-019                         Line E
>> 1            3              7.523163845262640E-037               -7.22224e-035                -7.22224e-035
>> 1            4              0.000000000000000E+000               7.22224e-035                 7.22224e-035
>> 1            5              1.684590875336239E-016                0                                       0
>> 1            6              0.129600000000000                         128623                            128623
>> 2            1              1.371273884908092E-019               0                                       0                                                Line F
>> 2            2             -7.222237291452134E-035
>> 2            3              7.222237291452134E-035
>> 2            4              0.000000000000000E+000
>> 2            5               128623.169844761
>> 2            6              0.000000000000000E+000
>> The red line (Line A, C, D and F) is the ghost values for 2 subdomains, but when run with 2 processor, the program treates Line B, C, D, and E as ghost values.
>> How can I handle this kind of local vector to global vector assembly?
>> Why are you not using DMDAVecGetArrayF90()? This is exactly what it is for.
> Thanks, Matthew.
> I tried the following codes but still cannot get the correct global rhs vector
> call DMDAVecGetArrayF90(da,x_vec_loc,vecpointer1d,ierr)
> do i = 1,nvz        !nvz is local node amount, here is 6
>   vecpointer1d(0,i-1) = x_array_loc(i)                              !assume x_array_loc is the local rhs (the third column in the above mentioned data)
>   vecpointer1d(1,i-1) = x_array_loc(i+nvz)
> end do
> call DMDAVecRestoreArrayF90(da,x_vec_loc,vecpointer1d,ierr)
> Now the rhs for 1 processor is as follows. It is not what I want.
> 1.39598e-021
> 0
> -0
> -0
> -0
> -0
> 5.64237e-037
> 4.81482e-035
> -0
> -0
> -7.52316e-037
> -7.22224e-035
> 7.52316e-037
> 7.22224e-035
> -0
> -0
> 1.68459e-016
> 128623
> 0.1296
> 0
>>    Matt
>> In fact, the codes can work if the dof and local node is as follows.
>> dof     local node
>> 1            1
>> 2            1
>> 1            2
>> 2            2
>> 1            3
>> 2            3
>> Thanks and regards,
>> Danyang
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
