[petsc-users] Memory corruption with two-dimensional array and PetscMemzero
Christophe Ortiz christophe.ortiz at ciemat.es
Tue May 20 07:12:45 CDT 2014
I found another problem when using two-dimensional arrays defined using
pointers of pointers.
When I use a "classical" two-dimensional array defined by
PetscScalar  array[dof][dof];
and then build the Jacobian using
ierr = MatSetValuesBlocked(*Jpre,1,&row,1,&col,&array[0][0],INSERT_VALUES);
It works fine.
The problem comes when I define the two-dimensional array as follows:
PetscScalar  **array;
 array = (PetscScalar**)malloc(sizeof(PetscScalar*) * dof);
 for (k = 0; k < dof; k++){
   array[k] = (PetscScalar*)malloc(sizeof(PetscScalar) * dof);
When I pass it to MatSetValuesBlocked() there is a problem. Either Petsc
complains because I am not passing it the right way or when it accepts it,
wrong data is passed because the solution is not correct. Maybe Petsc
expect dof*dof values and only dof are passed ?
How a two-dimensional array declared with pointers of pointers should be
passed to MatSetValuesBlocked() ?
Many thanks in advance.
Christophe
On Thu, May 15, 2014 at 2:08 AM, Jed Brown <jed at jedbrown.org> wrote:
> Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> > Hi all,
> > I am experiencing some problems of memory corruption with PetscMemzero().
> > I set the values of the Jacobian by blocks using MatSetValuesBlocked().
> To
> > do so, I use some temporary two-dimensional arrays[dof][dof] that I must
> > reset at each loop.
> > Inside FormIJacobian, for instance, I declare the following
> two-dimensional
> > array:
> >    PetscScalar  diag[dof][dof];
> > and then, to zero the array diag[][] I do
> >    ierr = PetscMemzero(diag,dof*dof*sizeof(PetscScalar));
> Note that this can also be spelled
>   PetscMemzero(diag,sizeof diag);
> > Then, inside main(), once dof is determined, I allocate memory for diag
> as
> > follows:
> >  diag = (PetscScalar**)malloc(sizeof(PetscScalar*) * dof);
> >   diag[k] = (PetscScalar*)malloc(sizeof(PetscScalar) * dof);
> > That is, the classical way to allocate memory using the pointer notation.
> Note that you can do a contiguous allocation by creating a Vec, then use
> VecGetArray2D to get 2D indexing of it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140520/1c89abed/attachment.html>
