[petsc-users] Equivalent of all_reduce for sparse matrices
Fri May 9 07:30:10 CDT 2014
On Fri, May 9, 2014 at 7:19 AM, marco restelli <mrestelli at gmail.com> wrote:
> 2014-05-09 13:14 GMT+0200, Matthew Knepley <knepley at gmail.com>:
> > On Fri, May 9, 2014 at 3:15 AM, marco restelli <mrestelli at gmail.com>
> wrote:
> >> 2014-05-09 5:47 GMT+0200, Jed Brown <jed at jedbrown.org>:
> >> > marco restelli <mrestelli at gmail.com> writes:
> >> >> Matt, thanks but this I don't understand. What I want is getting
> three
> >> >> arrays (i,j,coeff) with all the nonzero local coefficients, so that I
> >> >> can send them around with MPI.
> >> >> MatGetSubmatrices would give me some PETSc objects, which I can not
> >> >> pass to MPI, right?
> >> > I'm not sure you want this, but you can use MatGetRowIJ and similar to
> >> > access the representation you're asking for if you are dead set on
> >> > depending on a specific data format rather than using generic
> >> > interfaces.
> >> Jed, thank you. This is probably not the PETSc solution, but still it
> >> might a solution!
> >> I have found this example for MatGetRowIJ:
> > I really do not think you want to do this. It is complex, fragile and I
> > believe the performance
> > improvement to be non-existent. You can get the effect you want JUST by
> > using one function.
> > For example, suppose you want 2 procs to get rows [0,5] and two procs to
> > get rows [1,3], then
> > procs A.B
> >   MatGetSubmatrices(A, 2, [0,5], 2, [0,5], ..., &submat)
> > procs C, D
> >   MatGetSubmatrices(A, 2, [1,3], 2, [1,3], ..., &submat)
> > and its done. No MPI, no extraction which depends on the Mat data
> > structure.
> Matt, I understand that the idea is to avoid using MPI, but I don't
> see how getting a submatrix is related to my problem.
> Probably a simpler version of my problem is the following:
> one matrix is distributed on procs. 0,1
> another matrix is distributed on procs. 2,3
> The two matrices have the same size and I want to add them. For the
> resulting matrix, I want two copies, one is distributed among 0,1 and
> the second one among 2,3.
If you want distributed matrices to come out you could make one call to
MatGetSubmatrix() for each group, but that is unattractive for a large
number of groups.
I am not seeing the value you get by distributing these matrices if you are
just going to make copies later.
   Matt
A possibility that I see now is creating a third matrix, with the same
> size, distributed among all the four processors: 0,1,2,3, setting it
> to zero and then letting processors 0,1 add their matrix, and also 2,3
> add their own. Then I could convert the result into two matrices,
> making the two copies that I need.
> This works provided that in MatAXPY I can uses matrices distributed on
> different processors: given that the function computes
> Y = a*X + Y
> in my case it would be
> Y -> procs. 0,1,2,3
> X -> procs. 0,1
> Would this work?
> Marco
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140509/fb86fd67/attachment.html>
