[petsc-users] About left eigenvector for general eigenvalue problem
Fri May 2 14:36:09 CDT 2014
   Please send more information about how you tried to compute this and the matrix you used (if small just send the binary matrix or code that generates it). Vague questions like “why doesn’t it work as I expect?” are really hard to answer. With specifics about what was done and how the answer was different make the question easier and easier to answer.
   Barry
On May 2, 2014, at 2:02 PM, yuqing xia <yuqing.xia at colorado.edu> wrote:
> Hello everyone
> I am trying to solve a general eigenvalue problem.
> A x=\lambda B x
> I also need to get the left eigenvector
> y A=\lambda y B
> I tested the result  for a special case where A and B are real and symmetric. The left and right eigenvector should be the same. However, there are not.
> Then I tried to solve the problem
> A x =\lambda x
> The left and right eigenvectors are the same in such case. So I am wondering what is the reason. Thanks.
> Best
> Yuqing Xia
