[petsc-users] About left eigenvector for general eigenvalue problem
yuqing xia yuqing.xia at colorado.edu
Fri May 2 14:02:07 CDT 2014
Hello everyone
I am trying to solve a general eigenvalue problem.
A x=\lambda B x
I also need to get the left eigenvector
y A=\lambda y B
I tested the result  for a special case where A and B are real and
symmetric. The left and right eigenvector should be the same. However,
there are not.
Then I tried to solve the problem
A x =\lambda x
The left and right eigenvectors are the same in such case. So I am
wondering what is the reason. Thanks.
Best
Yuqing Xia
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140502/7a53c469/attachment.html>
