[petsc-users] Prometheus vs GAMG for elasticity/plasticity problems
Thomas Gross tgross at ilsb.tuwien.ac.at
Fri Jan 31 10:58:00 CST 2014
Please find enclosed the additional runs:
Prometheus:
-ksp_type cg -pc_type prometheus -log_summary -ksp_monitor -ksp_view -options_left -out_verbose 2 > Prometheus_verbose2.txt
GAMG:
-ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -log_summary -ksp_monitor -ksp_view -options_left mg_levels_ksp_type richardson -mg_levels_pc_type sor -pc_gamg_verbose 2 > GAMG_Rich_max_it_verbose2.txt
-ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -log_summary -ksp_monitor -ksp_view -options_left mg_levels_ksp_type richardson -mg_levels_pc_type sor -pc_gamg_verbose 2 -pc_gamg_repart true > GAMG_Rich_max_it_verbose2.txt
> And is this just a simple cube problem in elasticity as it looks like from your input file name?
The input is a cubic trabecular bone structure meshed with isotropic 8 node hexahedral finite elements (see attached cube_05.png). All elements were assigned the same elastic modulus and simulations were performed using small displacement formulation.
Best regards,
Thomas
Am 31.01.2014 um 02:29 schrieb Mark Adams <mfadams at lbl.gov>:
> I meant that GAMG isn't using BAIJ, but Prometheus is.  That affects
> kernel efficiency.
> Ah yes, that must be it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0005.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0001.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0006.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0003.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0007.html>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0004.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0008.html>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0005.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/4fc71c1b/attachment-0009.html>
